Best gears
Old Jun 2, 2011 | 08:55 AM
nlemerise's Avatar
nlemerise
Originally Posted by JOHN2001
If I go 40s I'll go 13.5 wide if I go 38s I'm gonna go 15.5 nitto mud grapplers either way thanks for your help fellas
Is the aspect ratio 80 (ratio of the sidewall height to tread width) as Jeff described?
Never mind...I calculated the aspect ratios and here is what I show for RPM.
Given 4R100 tranny, 4.30 gear, 40" tires (13.5" wide), 70 MPH = 1782 RPM:
Given 4R100 tranny, 4.30 gear, 38" tires (15.5" wide), 70 MPH = 1905 RPM:
And here is the 4.56 gearing info (just in case you wanted to compare):
Given 4R100 tranny, 4.56 gear, 38" tires (15.5" wide), 70 MPH = 2020 RPM:
Given 4R100 tranny, 4.56 gear, 40" tires (13.5" wide), 70 MPH = 1890 RPM:
Old Jun 2, 2011 | 11:00 AM
JOHN2001's Avatar
JOHN2001
Thanks Neal that's a big help. What are you guys spinning at 70 with stock gears so I know which one is the better ratio?
Old Jun 2, 2011 | 11:10 AM
nlemerise's Avatar
nlemerise
I believe my dually is geared at 4.10, so the RPM at 70 MPH with 235/85R16's would be 2159 RPM. With 3.73's and the same tires it would be 1964 RPM.
Old Jun 2, 2011 | 11:55 AM
JOHN2001's Avatar
JOHN2001
4:30 gears are looking good to me because I do like to get some kind of hwy fuel economy. 4:30 and I'm leaning more toward the 38s now
Ronnie Basil Smith
Aug 21, 2016 12:52 PM
terrylamar
Apr 12, 2016 09:44 PM
BigT_KY
Aug 19, 2015 07:54 AM
ferkules
Mar 15, 2008 10:26 PM
highboy1975
Offroad & 4x4
Dec 28, 2007 03:48 PM
