rear gears
Old Aug 18, 2016 | 12:53 PM
Ronnie Basil Smith's Avatar
Ronnie Basil Smith
rear gears
So I am getting 4.56 gears for my rear but I'm wondering, Is there any other parts I need for the rear beside the gears?
Old Aug 18, 2016 | 01:36 PM
Filthy Beast's Avatar
Filthy Beast
Ring & pinion gears come as a set as well as the shim packs, crush washer, etc...or they should. Some gear marking compound is a necessity to set correct backlash and preload. A dial indicator is a must, too.
Keep the shims in order, note the thicknesses and as to what side they go on and note the pinion shims, too. Bag and tag all the parts...keep the berrin caps separate and note their orientation - left, right, top and bottom.
I would change the carrier/pinion berrins as well, check the spiders for wear.
Old Aug 18, 2016 | 02:55 PM
HIO Silver's Avatar
HIO Silver
An overdrive transmission?
Old Aug 18, 2016 | 03:03 PM
jbehuniak's Avatar
jbehuniak
Depending on what you are changing from and which axle a new carrier also. Can you provide more details?
Doing some 1/8th mile?
Old Aug 18, 2016 | 10:17 PM
79finally's Avatar
79finally
The carrier split is between 4.10 and 4.56. When jumping this gap you have to change carriers.
Old Aug 19, 2016 | 07:45 AM
Ozzie H.'s Avatar
Ozzie H.
Maybe a gasket for the cover.
Old Aug 21, 2016 | 12:52 PM
351Cleveland C4's Avatar
351Cleveland C4
Or 37" tires....
Sooper-Doodie
Jan 13, 2009 08:30 PM
frmrdodgedriver
1997 - 2003 F150
Jan 22, 2005 08:52 AM
ParisDakar
Dec 10, 2004 10:49 PM
Hell_Fish
Bronco II
Jul 12, 2004 10:25 PM
1990F2504X4
Jan 23, 2004 04:43 PM
