fuel pump removal/install
Old May 31, 2011 | 09:30 PM
hedhntr's Avatar
hedhntr
I ordered my t500 today and read where i need to pull the fuel bowl so i figured i would rebiuld the housing with all new orings since i cant find the leak, also i have a new fuel pump that i figured i would put in just because i have one. any write ups on the fuel pump removal/install. Thanks
Old Jun 1, 2011 | 04:09 AM
Copedawg's Avatar
Copedawg
Here is my Cali model write up: https://www.ford-trucks.com/forums/6...placement.html
It is smart/wise to rebuild the bowl/houseing at the same time. Is this a weekend project?
Old Jun 1, 2011 | 07:37 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Most important thing I can think of to say is that when you unbolt the old pump, rotate the motor by hand and watch and make sure the pump rises up off the block. This will put the cam lobe as high as possible and prevent the tappet from falling in the motor.
Also, be careful if you have to pry the old pump off, sometimes they break off in the engine block.
Otherwise it's not too bad of a job.
Good luck.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
E450 newbie
Dec 13, 2015 08:44 PM
playsintraffic
Jan 26, 2015 03:32 PM
Firebird racer
Dec 19, 2014 07:09 PM
IcemanV8
Jun 19, 2014 05:55 PM
pcmpete
Escape & Escape Hybrid
Aug 3, 2011 12:33 AM
