2001 F-350 Dually, Previous owner put 19.5's on, going back to OEM wheels. They cut the wheel studs off to clear the adapter and rim so I have to replace all the studs.
How do you replace the wheel studs on these things without taking the front hubs off or the axles out?
Do they make a removal/install tool big enough for this? I've seen the Tie Rod style tool used on smaller cars.
Front or rear or both? Front has a spacer so just unbolt the spacer push out the cut studs and push in new ones. The rears your gonna have to remove the hub push out cut studs and push in new ones then bolt the hubs back onto the axle
