Exhaust
Old May 30, 2011 | 08:37 PM
openexcess's Avatar
openexcess
Exhaust
I have a 04 F250 6.0 PS and was wondering if it would hurt to unbolt the exhaust right before the muffler (or cut it off) I plan on getting a full MBRP exhaust but not for another couple months. will this hurt the performance of the truck or should I just leave it? I want to get rid og the cat and the muffler if possible
Old May 30, 2011 | 09:05 PM
nogo73's Avatar
nogo73
get a programer and cut them both off. Believe the sct programer will do what you want but I know my 6.9 idi loved it when I cut the muffler off.
Old May 30, 2011 | 09:09 PM
openexcess's Avatar
openexcess
Will I have to get a tuner immediatly? I was hoping I could just cut off the muffler/cat and roll on
Old May 30, 2011 | 10:14 PM
nogo73's Avatar
nogo73
if you have a 02 sensor behind the cat then you need a programer
Old May 30, 2011 | 10:21 PM
nogo73's Avatar
nogo73
if not start cutting
Old May 31, 2011 | 06:02 AM
redford's Avatar
redford
FTE Leadership Emeritus
You should ask the question in the 6.0L PSD forum. A turbo-back straight pipe is a common and beneficial modification.
Old Jun 1, 2011 | 01:30 AM
flyer7.3's Avatar
flyer7.3
03 7.3, I installed a 4 inch duell exhaust with muffler, wasn't the sound I wanted so I got rid of the muffler, sounds horny as now.
I will have to reinstall the muffler next month for rego though.
Ya gotta let diesels breathe.
Old Jun 2, 2011 | 08:59 AM
bravanc's Avatar
bravanc
i have an 04 f250. you can remove the cat and muffler if you want and straight pipe it. i would recommend you get the kit and just do it all at once.
Old Jun 2, 2011 | 09:05 AM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Jun 2, 2011 | 09:11 AM
cmdevildog16's Avatar
cmdevildog16
i have been thinking bout doing this as well (removing the cat and muffler) can you just get some 4" exhaust pieces and put them in place of those two?
Old Jun 2, 2011 | 09:51 AM
bravanc's Avatar
bravanc
you can if the existing pipe is 4" otherise you will have to get adapters to go from whatever size you have to to 4" and back down. You can cut the cat and muffler off and straight pipe just those two. Still will have to get adapters or have the muffler shop expand both ends of the straight pipe so that they will slip on. Don't forget the u-bolts to clamp them in place.
Old Jun 2, 2011 | 11:16 AM
cmdevildog16
yeah cause i was talking to a guy at napa and they can get a 4" pipe with the ends flared so that the inside diameter is 4" so it will slide right on and then clamp it in place
Old Jun 2, 2011 | 12:16 PM
Ian123's Avatar
Ian123
diesels dont have o2 sensors
Old Jun 2, 2011 | 05:14 PM
openexcess's Avatar
openexcess
Im just going to order this
Amazon.com: MBRP S6212PLM Turbo Back Single Side Off-Road Exhaust System: Automotive
zakk
17
Mar 20, 2011 01:45 AM
shawn55
Exhaust Systems
18
Apr 20, 2010 01:30 AM
Powerstrokeredneck70
Sep 9, 2008 03:04 PM
mooncricket
Aug 30, 2008 08:31 PM
Trucker51
Modular V10 (6.8l)
Apr 17, 2008 10:56 AM
