Ok i put a 1993 trans into my 90 the only thing that had to change was the was the shaft to hook up the shifter.
This is whats hapening it feels like the torqu converter is locked up when you put the shifter in drive.
works good in reverse
works good if you manually shift it.
Trans was rebuilt had about 4 months use before the 93 was totaled.
So what how may be wrong?
Am i right that this sound like some thing wrong with the electonics?
Yes i rather buy my gator tags than pay 1100 for a rebuilt trans instaled.
This is my back up truck well sort of the bronco ate a dodge truck at 55 mph But its back on the raod but creaking and moaning.
