air bags
Old May 28, 2011 | 10:59 AM
ivplay's Avatar
ivplay
air bags
The air bag dash light flashes so I'm wondering what is wrong? Its a 1995 f150 351w. Any help and I will be grateful.
Old May 28, 2011 | 12:22 PM
Edgethis's Avatar
Edgethis
When does it flash? Just on start up?
Old May 28, 2011 | 02:44 PM
86F150302's Avatar
86F150302
It will be flashing a code. Count the flashes just like you would the check engine light and you can see whats wrong.
Mine has been flashing a 34 for 2 weeks now..
Airbag Codes
12 Low Battery voltage
13 Air Bag Circuit Shorted to Ground
14 Front Air Bag Sensor and Bracket Circuit Shorted to Ground
21 Rear Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
22 Rear Air Bag Sensor and Bracket Output Circuit Shorted to Battery Voltage
23 Rear Air Bag Sensor and Bracket Circuit Input Feed/Return Circuit Open
24 Rear Air Bag Sensor and Bracket Output Feed/Return Circuit Open
32 Driver Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
41 RH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
42 LH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
44 RH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
45 LH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
51 Air Bag Diagnostic Monitor Internal Thermal Fuse - Fuse Blown Due to Intermittent Short to Ground
52 Backup Power Supply - Voltage Boost Fault
53 Front Air Bag Sensor and Bracket Circuits Resistance to Ground or Air Bag Diagnostic Monitor Fault
- Rapid Continuous Flashing of Air Bag Indicator (No Fault Code) All Primary Air Bag Sensors Disconnected
- No Air Bag Indicator - Inoperative Indicator Circuit or No Battery Positive Voltage to Air Bag Diagnostic Monitor
- Continuous Air Bag Indicator - Air Bag Diagnostic Monitor Disconnected or Inoperative
Old May 28, 2011 | 02:52 PM
redlightning93's Avatar
redlightning93
Does your Cruise Control work? Horn blow?
Old May 29, 2011 | 06:58 AM
ivplay's Avatar
ivplay
Airbag Codes
OK. VERY INFORMATIVE! THANKS
thunderbolt427
1997 - 2003 F150
Jul 9, 2007 09:45 PM
Hawk180
Feb 13, 2007 09:32 PM
mattmorty
May 4, 2006 10:35 PM
AAS
1978 - 1996 Big Bronco
Nov 9, 2003 05:45 AM
