Sponsored by: Real Truck
Trans expert needed
Old Mar 14, 2009 | 08:12 PM
bubbasz1's Avatar
bubbasz1
Trans expert needed
I had posted a couple of times from the beginning of basic trans problems to finally the end. I've learned a lot and I'm going to paint a little picture of what happened.
First off basically the 4r100 V10 with a mechanical diode (in pieces). My son and I pulled the trans and was rebuilt by someone that was recommended to us. He works out of his garage, makes a living doing transmission work. $750.00 later with a rebuilt converter it was back in the truck, but it wouldn't function, shift properly, no reverse, no 2-3 shift, or not like it should and that anoying light flashing on the shifter. After playing with it checking line pressures ect, mind with the help of the transmission repairman buy my side we pulled the trans out again. Only took two hours the second time around, amazing what you learn the first time. Trans was tore down and nothing was amiss. Well turns out the trans rebuilder's buddy has a trans dyno so off to the dyno it goes. Well it worked just like it should so back in the truck it goes, and guess what, it works like a champ>>>for 30-or 40 miles and then, same old stuff, no reverse, won't shift into 3rd, holy crap. So back in the garage BUT this time we pretty much know the trans guts are good OK so what do we do. When I had the trans out the second time I had the shift solenoid harness hooked up to my Auto Enginuity and shifted the solenoids manually so the PCM is working and the harness should be OK. Well this morning while I was drinking my coffee I had a thought so when my son showed up I had my Trustworthy son climb under the truck while it was running in reverse and shake the wires on the solenoid pack around and guess what all of a sudden the truck goes in reverse(did I mention it's his truck and he hasn't drove it in three months, I also had my foot planted on the brakes, come on it wasn't unsafe)beside the garage door was closed and I surly wouldn't ruin that, cost too much to fix. I back it out of the garage and around the block and it works like brand new. I called the trans dude up and he was you got to be kidding me. So now the people who have read this are going WTF are you babbling about this is crap.
When you work on your trucks don't leave any stone unturned, don't point to the obvious (pulling trans out after it didn't work) play, putz, do stupid stuff, I even got words of wisdom from the FTE and guess what!! At least I know whats wrong.
Sorry for the babbling but as much as we work on our trucks don't do what you think is the problem until your pretty darn sure you know what the problem is.
Monday we get a new solenoid wire patch harness and we should be good to go.
Old Mar 14, 2009 | 10:19 PM
F350-6's Avatar
F350-6
Thanks for the story. I would have though an issue with the solenoid pack would have thrown a code, especially with the flashing OD light. Did you not get any codes that gave you a hint as to what was going on?
Old Mar 14, 2009 | 10:29 PM
bubbasz1's Avatar
bubbasz1
Was getting codes at one time or another, 1-2 shift or 2-3 shift, but the no reverse was a hangup. At one time I had no reverse until I got a code and then it worked?? The thought was it codes out, kicks in extra line pressure and wala you have reverse. Well evidently with the bad wires it was ... who knows, doing something in the solenoid pack that reverse didn't like. It did it again this afternoon, just moving the truck out of my way, little giggle and backwards we go. Did I metion in my first post that I hate electrical BS.
Old Mar 15, 2009 | 08:53 AM
tex25025's Avatar
tex25025
I had a similiar issue with my fuel pump. Thinking all the time it was a bad pump and it turned out it was a wire grounding out and not getting juice to the pump.
AussieAahz69
24
Apr 20, 2025 11:02 AM
94-Str8Six
16
Jan 31, 2015 08:36 AM
FORD MEGA CAB!!!
Jul 6, 2012 08:40 PM
bubbasz1
Mar 7, 2009 05:18 PM
jtharvey
45
Jun 11, 2006 03:34 PM
