'50 Starter Stud
Old May 26, 2011 | 09:46 AM
saxtonj's Avatar
saxtonj
'50 Starter Stud
Hello,
The copper stud on my '50 Flathead V-8 6 volt starter is stripped out. How hard is it to replace... ? Would it be easier to get a dye and make it smaller? What is your opinion on resolving the issue?
Thanks!!
Old May 26, 2011 | 10:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
18-11102-B .. Starter Terminal / Obsolete
ANTIQUE AUTO SUPPLY in Arlington TX has 31 = 817-276-2381.
A9A-11102-A .. Starter Terminal Repair Kit (includes 18-11102-B, 4 different washers, bushing & nut) / Obsolete
ANTIQUE AUTO SUPPLY has 1.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
JST AUTOMOTIVE in Lebanon TN has 2 = 615-443-3086.
BISON MOTOR CO. in Great Falls MT has 3 = 406-727-2552.
GREEN SALES CO. in Cincinnati OH has 9 = 800-543-4959.
Old May 26, 2011 | 05:39 PM
bobj49f2's Avatar
bobj49f2
It's a fairly easy fix. It has a grove on the part that is inside the starter that field coil leads solder to. You'll need a larger soldering iron to desolder and resolder the leads. There are insulating bushings surrounding the stud so it doesn't ground out on the case. It's been quite some time since I had to do mine but it wasn't that hard.
If you haven't already removed the starter front the truck just remember when you remove the two bolts holding the starter to the bellhousing be careful when pulling it out. It will come apart in pieces.
BTW, post somewhere where you're located, maybe some one is nearby with experience doing this and is willing to lend a hand. You can list you location in the upper right corner of your post by editing your profile.
Old May 31, 2011 | 08:46 AM
saxtonj's Avatar
saxtonj
Thanks for taking the time to reply. The info is VERY helpful!
Rusty_S
22
Feb 8, 2015 07:07 PM
JoeHarbourJets
Nov 7, 2011 09:12 PM
Tony1995
Oct 19, 2011 10:00 AM
jmarro1
Sep 22, 2010 06:47 AM
txmnjim
Nov 14, 2009 09:17 AM
