before and after pics
Old May 25, 2011 | 01:07 AM
traxx808's Avatar
traxx808
wow that looks great. wish i had time for that. wanna do mines next! lol! what brand rust converter and rust reformer did you use? was it from the eastwood comp.
Old May 25, 2011 | 01:36 AM
waskin27's Avatar
waskin27
I am on a laid off budget, haha , so I used napa brush on rust converter, with some rustoleum rust reformer that actually works surprisingly good, I also put some profession grade rust resistant rubberized paint over the reformer and so far after about 3 months in the michigan winter and all this rain here it hasnt rusted through. If you went with the napa converter I'd put two to three heavy coats on if rusted bad ... the bottle says thin coats but thats only if its light surface rust. I tried thin coats and exposed my test metal(a piece of my rusty rear wheel arch) to the elements for a couple days and it started to show through, but the heavy coats did well.
Old May 25, 2011 | 12:13 PM
waskin27's Avatar
waskin27
Has anybody put studs in used snow tires, I have the cooper discoverer m+s tires with the stud holes, but im not sure if 80% tread is good enough since ive heard you shouldn't stud used tires.
Old May 25, 2011 | 08:58 PM
mikeismadness's Avatar
mikeismadness
one thing u could also look into with fixing your bed is LMC truck has bed sides usually
Old May 25, 2011 | 09:36 PM
octaneforce's Avatar
octaneforce
i was thinking the same thing. sheet metal could get messy unless your really good with the body work.
Old May 27, 2011 | 01:36 AM
waskin27's Avatar
waskin27
I was planning on fixing the wheel arches with repair panels and the bed floor with sheet metal then just throw a liner in.
propellerhead
15
Apr 25, 2017 12:28 PM
Raleigh1
1978 - 1996 Big Bronco
682
Mar 18, 2016 01:29 PM
MOOSE_MACHINE
Testing.....
Mar 18, 2014 07:03 PM
postoak99
1997 - 2003 F150
Mar 5, 2011 11:05 AM
