83 f150 dash removal
Old May 24, 2011 | 05:05 PM
albinorhino's Avatar
albinorhino
I am trying to remove my dash to fix my a/c cable. does anyone know how to remove the head light **** and wiper ***** with out breaking them. Also if anyone has any suggestions on how to fix the cable on the heater AC control in the dash. Please feel free to speak up.
Old May 24, 2011 | 05:11 PM
billt28's Avatar
billt28
I use a cotter pin puller, its shaped like a 7 and hook it behind the ****. Theres a spring there that you need to push on as you pull on the ****. Good luck.
Old May 24, 2011 | 07:03 PM
TheKirbyMan's Avatar
TheKirbyMan
Reach up under the dash and feel for a small button on the bottom of the headlight switch. You press it as you're pulling the headlight switch out, and the **** and shaft come out as one piece. To remove the wiper ****, you use billt28's method.
Old May 25, 2011 | 03:02 AM
Ken Blythen's Avatar
Ken Blythen
On some years (I think it's the Haynes manual that mentions it) the switches were up the other way, with the button on top.......mine, also 83, is like this.
It's not the most comfortable of jobs anyway, but especially if you're hunting in the wrong place for the button.
There is a notch on the front (nearest the dash panel) of the wiper **** - that is where you need to pull back on the spring clip to release it from the shaft.
Old May 25, 2011 | 09:08 AM
Alcaeus's Avatar
Alcaeus
A small allen wrench works fine too.
Old May 25, 2011 | 10:58 PM
TheKirbyMan
I've gotten 'em off by wiggling 'em. lol
Old May 26, 2011 | 10:22 PM
albinorhino
Thanks guys that worked great. But do you have any suggestions how to get the climate control unit from out of the dash so I can replace the temperature cable? So I can go from hot to cold air.
Old May 27, 2011 | 07:30 AM
ctubutis's Avatar
ctubutis
https://www.ford-trucks.com/forums/1...or-switch.html
Old May 31, 2011 | 09:07 PM
albinorhino
Does any one know where I can get a new cable for the climate control unit. Its getting summer and I need it go from hot to cold? no parts store in my area carries it.
Old May 31, 2011 | 09:20 PM
ctubutis's Avatar
ctubutis
What year? You say ONE cable, that implies you have AC, correct? Without AC, you have two cables.
Old May 31, 2011 | 09:30 PM
albinorhino
Its on a 83 f150 and I have AC.
Old May 31, 2011 | 09:56 PM
ctubutis's Avatar
ctubutis
E3TZ-19988-A CABLE ASSY. (AIR CONDITIONER TEMPERATURE CONTROL) Fits 1983 F150/350 & Bronco
Our sponsor Ed Olson www.partsguyed.com has it - MSRP $32.47 Ed's FTE discount price $23.38
atomicjoe23
28
Jul 12, 2015 06:52 PM
rnelson664
Jan 29, 2015 05:45 PM
1964FORDTUF
Mar 9, 2014 04:59 AM
Indecl
Apr 8, 2012 05:30 PM
ken 01
2004 - 2008 F150
Jan 15, 2011 11:22 PM
