Alt warning light came on
Old May 24, 2011 | 01:32 PM
Schuyles's Avatar
Schuyles
1965 f100 240
the "alt" light stayed on today, and the engine seemed to be running a little rough. The engine thing might have been me being paranoid, but the light is definitely on.
I am going to stop by autozone on the way home to have them check the battery and alternator. The battery is 5 years old, and the alternator...who knows. I've never changed it.
Any other suggestions?
Old May 24, 2011 | 02:36 PM
CropDusterMan's Avatar
CropDusterMan
I'd check your grounds too, be sure there is a good contact there...corrosion maybe?
Good luck....BTW, how do those college girls like your old Ford?
Old May 24, 2011 | 09:48 PM
garbz2's Avatar
garbz2
Tap on the voltage regulator as they stick.
Garbz
Old May 26, 2011 | 01:51 AM
Schuyles's Avatar
Schuyles
I took it to autozone and they checked the battery (good) and the alternator. He said the alternator was not generating enough power...so for 45 dollars, I bought the replacement. I put it in tonight, and the light is still on.
What else could it be? Voltage regulator? (I tapped on it garbz)
Old May 26, 2011 | 01:52 AM
Schuyles's Avatar
Schuyles
They can't get enough! I only have one lap belt, on the driver's side, so I always tell them they have to buckle up with me!!
Old May 26, 2011 | 05:14 PM
garbz2's Avatar
garbz2
Replace the cable from the block to the frame and replace the battery cables. Once these are found to be good. then replace the voltage regulator.
Or i would just put a simple one wire GM unit on it and call it a day with junk regulators old wiring and crap.
Garbz
Old May 26, 2011 | 10:56 PM
Redmanbob's Avatar
Redmanbob
Clean up all the connections before replacing parts that are just fine. If the alt is charging like it should then pull the volt reg and remove the cover. Reinstall and watch it to see if the unit is sticking open. The points should open and close as the charge is needed.
Old May 26, 2011 | 11:02 PM
CropDusterMan
Ha! I had a good laugh there Mate....that's one of the most original lines
I've heard yet. Good to see that youth is not always wasted on the wrong
people! Dang....to be in my early 20's again.
Good luck, study hard.
Jason
adamsrancho
Jun 21, 2024 07:16 AM
dano89406
Sep 15, 2012 02:03 PM
Wisebuck
Sep 8, 2011 01:53 AM
MONAVIERONJON
Sep 2, 2010 07:59 PM
KGB
Electrical Systems/Wiring
Aug 21, 2009 05:41 PM
