Alternator problem long read
Old Aug 20, 2009 | 08:42 PM
KGB's Avatar
KGB
1999 F250 Super Duty -4x4 -5.4L w/air 76000 miles on truck.
Tuesday driving truck battery light comes on and noticed on ac and slow wipers.
Go home park truck turn off engine ,try to restart dead (alternator).
Wensday morning remove alternator install excel alternator ,wrong alternator ,it was for F250 but not super duty.
OK no problem just change it for the right one ,install another excel still not getting any charge from alternator . reading on battery do not go over 11.95 engine off 11.78 idle 11.46 idle & air on . This I would say is a bad alt (yes?) . have mechanic check it, says bad alt (11.60)
Thursday 3rd alt --napa alt install still same problem .
This is on a new napa battery as of wensday , unhooked battery before removing alt . checked bat cables to make sure all clean.
napa store said they tested three and tested bad.
mechanic said he has seen the same thing need to get dealer rebuilt.
Am i not doing something right or missing somthing ?
If posible can someone please tell me where the three wires go to on the three wire clip .
Thank you very much
I only did this job because alt easy to get to and only three bolts.
Takes longer to get the part then put it in
Old Aug 20, 2009 | 09:26 PM
Mustang6147's Avatar
Mustang6147
I just think they got a bad batch of Alternators. NAPA is reputable. Soemone may have swapped them out, who knows. I would have 1 tested before you put it in. Maybe buy it, then take it to another place, have them test it, if it is good then put it in. If it goes south, You know its a truck problem, and you can still return it to your purchase place, since they didnt test it, and wont know any better.
Old Aug 20, 2009 | 09:33 PM
KGB's Avatar
KGB
I on good terms with this parts house and they trying to do what they can for me to solve this problem.
Am i shorting it out when installing alt?
Old Aug 20, 2009 | 09:35 PM
Franklin2's Avatar
Franklin2
The later model trucks have some fuses in the underhood fuse box for the alternators, so check them out also, though that would not explain why the three alternators tested bad.
Old Aug 20, 2009 | 09:37 PM
Mustang6147
If the battery is disconnected, while installing it, I dont see how. Unless, a wire has be burned or chewed , or is rubbing on another serface... Like a hot positive rubbing on the engine which is grounded... It may still just be a bad battery.
When you battery is dead, your regulator tells the alternator how much juice it needs to bring it up to full charge. If a new altornator is put in, and the battery is dead. The voltage regulator slams wide open, and the new alternator gets hot, and cooks.
Maybe since you replaced the battery your problems will be solved... How bad was your battery?
Old Aug 20, 2009 | 09:49 PM
KGB's Avatar
KGB
Truthfull with you the battery I took out came from advance auto when alt went bad .
It was only 2 years old but after alt went I thought it would be better to put in a new battery.
New as of today
Old battery from advance auto tested as-- volts11.80 --273 cca --rated600cca temp.
they did a 30min charge ----volts 12.85-- 814cca-- 600cca after charge but this battery is not in turck
Old Aug 21, 2009 | 05:41 PM
KGB's Avatar
KGB
Case closed problem fixed fusable wire link .
Thank you.
gumbydamit
Electrical Systems/Wiring
13
Dec 22, 2021 08:45 AM
jasindude1
Sep 18, 2014 02:33 PM
Slankky
Aug 19, 2012 02:02 PM
rwtdct
Aug 7, 2012 08:05 PM
Rusty01
20
Sep 6, 2005 10:52 PM
