troublesome backup sensor
Old May 22, 2011 | 05:32 PM
charger212's Avatar
charger212
Does anyone know how to diagnose a backup sensor system? Mine turns off when I put it into reverse. It doesn't appear that any of the bumper sensors are damaged. I am not to good when it come to anything with juice running through it. It was like that when I bought it and I sure would like it to work. Thanks!
2005 F250 6.0 PSD
Old May 22, 2011 | 05:42 PM
bismic's Avatar
bismic
I have heard of this tip ............... You can put your truck in reverse and put the parking brake on (make sure the parking brake is solid!). Then walk around and put your ear up to each sensor. The sensor that is not making the clicking noise is the one that is bad.
Part # (about $75 each at Tously)
YL1Z15K859AA
Hope it works.
Old May 22, 2011 | 06:33 PM
charger212's Avatar
charger212
I'll be darned, it worked! thank you very much.
Old May 22, 2011 | 06:37 PM
bismic's Avatar
bismic
How about that!
Let us know where you found the replacement sensor(s) if you can beat the $75 price.
Old May 22, 2011 | 06:44 PM
wulfman's Avatar
wulfman
I have a similar problem a tow strap came louse and a D ring punched one sensor out with a big dent in the bumper, bought new sensor put it in and nothing. Any ideas.
Old May 22, 2011 | 07:03 PM
bismic's Avatar
bismic
Wulfman - Did you check the connector on the damaged sensor? Is the connector to the damaged sensor getting power (check voltage)?
OP - IIRC - tips on replacement:
There are two clips on the inside of the bumper that hold the sensor in place. If you tap the sensor through with a socket you will break the clips. Both of the clips are on one side of the sensor at 2 and 4 on the clock.
Fastfwd
May 21, 2014 01:07 PM
380tom
Feb 26, 2013 10:04 PM
Ironhide
Dec 24, 2012 05:01 PM
NewEnglandHerdsman
Escape & Escape Hybrid
Jun 10, 2011 04:12 PM
catman700
2004 - 2008 F150
May 19, 2008 09:58 PM
