INFO
Old May 22, 2011 | 02:22 PM
JER1517's Avatar
JER1517
INFO
Well I'm back from a long deployment and need to pick someones brain. I have a 63 Styleside with what I believe is a 302 and a C6 transmission just not sure the specs of the motor. The numbers on the block read EOAE D3C and a 19 turned sideways also the is 3H261 on the block also. Anyone with a idea of what this really is any help would be great. Thanks
Old May 22, 2011 | 11:18 PM
SuperSabre's Avatar
SuperSabre
Your best hope is for Number Dummy to see this post and give you the straight scoop. While waiting for him, I might be able to provide some info by extrapolating it from the Steve Christ book, How to Rebuild Big-Block Ford Engines. I realize the 302 you think you have is not a big block; but as far as I know, casting numbers are similar. EOAE should indicate a 1980 or later casting - which has nothing to do with final machining. 3H261 should pinpoint the production date of the engine as 1983 August 26. Sadly, I don't know what the D3C means or the sideways 19. There is a small block engine forum down a few lines in the forum section. Try asking your question there and maybe someone will know. Good luck.
Old May 23, 2011 | 04:48 AM
jowilker's Avatar
jowilker
JER1517, Welcome home, Thank you for your service to our country.
John
Old May 23, 2011 | 10:48 AM
Buzz44's Avatar
Buzz44
Thumbs up
John
xxxxxxxxxxxxxxxxxxxxxxx2
Old May 23, 2011 | 12:56 PM
daveengelson's Avatar
daveengelson
[QUOTE=jowilker;10374774]JER1517, Welcome home, Thank you for your service to our country.
Me to!!!
Suggest going to the "Small Block V8" forum, at the top of the list of thread there's a Block Casting # catagory and info looking for may be there.
Old May 23, 2011 | 05:29 PM
99hosss's Avatar
99hosss
Thanks for keeping us safe, friend. Not sure about the block info, but will help out with issues if I can
Old May 23, 2011 | 08:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E0AE-D3C = 1980 block casting number. Since casting numbers are foundry marks, they cannot be cross referrenced to Ford part numbers. My guess is, it's a 302 or possibly a 351W.
3H2 = Block cast the second week (2) of August (H) 1983 (3) / 61 is the code for the foundry that did the casting.
Chris Guthro
Jun 18, 2020 10:12 AM
No More Raptor
13
Dec 3, 2013 02:26 PM
jwtimme
Mar 27, 2004 07:12 PM
335clevo
19
Oct 18, 2002 11:26 PM
Fordman7780
Oct 10, 2002 10:57 PM
