D1VE AA block ?
Old Oct 10, 2002 | 07:53 PM
Fordman7780's Avatar
Fordman7780
D1VE AA block ?
I might buy a engine that has D1VE AA block to use to build a stoker engine
Is this a good block to use for that and is this block a 429 or 460 block and does it have thick cylinder walls for boring far over
The engine also have DOVE-C heads on it what size valves are in it and what cc are they
Old Oct 10, 2002 | 08:39 PM
georgedavila's Avatar
georgedavila
D1VE AA block ?
You have a desirable block in that it has thick main bearing webs that can easily converted to 4-bolt mains. Cylinder thickness should be the same as other 385 blocks. If you plan to go more than .080 oversize on the bore, have it sonic checked.
DOVES are 75-78cc with standard production sized valves. 2.09Intake, 1.65E.
Old Oct 10, 2002 | 10:25 PM
FORDNUTTZ's Avatar
FORDNUTTZ
D1VE AA block ?
that block is a good one 2 build power with
what kind of stroker setup r u planing 2 use?
also u can leave it 2 bolt and use a gertile and you shouldnt have no flex
4 bolt caps an d the machine work is high doller
Old Oct 10, 2002 | 10:57 PM
91f250460's Avatar
91f250460
D1VE AA block ?
TexasGuy001
20
May 21, 2021 09:20 AM
ford69gt
Jun 13, 2016 03:10 PM
Aaron-71
Oct 9, 2015 07:13 PM
66_in_ky
Jun 29, 2008 07:52 PM
DTL504
Jan 27, 2005 10:02 AM
