WHITE SMOKE HELP
Old Jun 11, 2011 | 07:14 AM
4mrBowTie's Avatar
4mrBowTie
Thanks Sulli, I will go try to check now. Hoping to find some info before I depart. Am contracted to instruct a firearms course so not showing up isn't an option. I guess if all else fails....I'll begin the treck and if something happens, I will have AAA tow it to a dealer in WV and have them make whatever repairs are needed. But I HOPE it doesn't come to that. Can't thank you guys enough for the insight and assistance/information.
Old Jun 11, 2011 | 07:16 AM
4mrBowTie's Avatar
4mrBowTie
Old Jun 11, 2011 | 07:33 AM
bismic's Avatar
bismic
If you want to change the EGR cooler out (or delete it) and change the oil cooler (which was likely to be the original problem), I can email you some helpful material. PM me w/ an email address if you are interested.
Old Jun 11, 2011 | 07:40 AM
4mrBowTie's Avatar
4mrBowTie
Bismic,
I just posted Message awaiting info when you get the chance. Thanks again.
Old Jun 20, 2011 | 06:33 PM
4mrBowTie's Avatar
4mrBowTie
White Smoke Solved
Well, After changing Oil and filter, No coolant in oil. I took it to dealer for evaluation/ service/ I was under time crunch and was headed out of town. $2917 later.....they had to replace the EGR cooler and the EGR valve. I asked them to bypass the EGR cooler. They wouldn't do it. I got frustrated and asked if it was the head bolts, they would replace with APC studs, so why not bypass the problematic cooler. I guess time will tell if it was a long term fix, Thanks to all who gave input and assistance. Any Diesel techs here who could shed light on why they wouldn't bypass the known problematic EGR cooler? Is the replacement better engineered than the original?
Old Jun 20, 2011 | 06:36 PM
BLADE35's Avatar
BLADE35
the dealer would lose there license if they got caught deleating the egr system it Federaly required
You need to put on the BPD egr cooler this one is next to bulletproof
there was some talk a few weeks ago about maybe ford upgraded the egr cooler
hope there changiing the oil cooler to thats usualy the cause of the egr cooler failure
Old Jun 20, 2011 | 06:46 PM
bismic's Avatar
bismic
For sure !
4mrBowTie - I think I failed to send you the cooler info. Instead I think I sent you the "General" spreadsheets. At least this is what I recall sending you - in my defense, I send a lot of people info.
Sorry to be late in replying.
BTW - the 6.0L will not put coolant into the oil w/ head gasket or EGR cooler issues.
Old Jun 20, 2011 | 07:27 PM
4mrBowTie's Avatar
4mrBowTie
White Smoke Help!!!
Blade and Bismic,
Thanks to you both. Got the truck back. They said Head Gaskets were good. As for Oil Cooler, I haven't been able to talk with Tech yet. Asked the service Rep to have Tech call me. had some general questions for him as far as what can help keep this from happening again. I run Diesel Kleen every 3rd tank of fuel, run Only BP 47 Cetane fuel etc. I will type everything the service sheet says they did.
"Verified concern degas bottle empty pressure test cooling system. Cap and bottle OK. EGR cooler fails. Replaced EGR cooler. Install Oil Cooler service kit and EGR valve. Changed oil and filter. Flush and refill cooling system and road test. Retest to monitor head gaskets. All okay"
Bismic, no worries on data sheets you sent. If you get the chance, please send EGR cooler bypass info if you have it and can remember. I will bypass the first chance I get.
Old Jun 20, 2011 | 07:39 PM
BLADE35's Avatar
BLADE35
sounds like they changed the oil cooler
I dont know what eles a oil cooler service kit would be
if you dont already get some gauges so you can keep an eye on it
Old Jun 20, 2011 | 08:42 PM
bismic's Avatar
bismic
The oil cooler service kit is an oil cooler "core". It is fine to fix it this way.
I really don't have much on EGR deletes. The spreadsheet on MODS should have some links for you. I am not much into the EGR delete. I am OK w/ keeping mine (bulletproof one).
Regulator1988
Jan 8, 2013 05:30 PM
wildbyon
Jun 3, 2010 08:57 PM
weldingfreak
Feb 12, 2006 03:10 PM
greenhedhntr
Nov 26, 2004 01:50 PM
kitsapcountychopper
25
Mar 19, 2004 08:11 AM
