Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Ugly Bead Breaker
Old May 19, 2011 | 08:36 PM
monckywrench's Avatar
monckywrench
Ugly Bead Breaker
This was inspired by the slick Van Natta tire press, so credit where due (and check out the rest of the website!)
Tire Dismount Press
I don't have a nice porta-power like theirs, and needed to strip some old tires so I can use the rims for jackstands and for scrap aluminum. Long bolt is to fit larger tires.
My setup uses one fixed shoe and a large cement anchor provides the shaft and nut. The center hole allows fine adjustment. Anchor is welded to the bottom beam. Shoe is torch-cut with a curve to match the rim. Grind it smooth if you are saving the tires.
The nut provides enough leverage to break most tires, and the preload in combination with the improvised "bead buster" pipe-over-prybar (bar is a Klein Grizzly but anything similar would do) works fine on nasty rims like that shown.
I spray or pour leftover ATF or oil on the joint when dealing with horribly rusted rims, then bust them the next day. (Oil your Sawzall blade or silicone it when cutting off old tires if you go that route.)
Old May 20, 2011 | 12:31 PM
Ford_Six's Avatar
Ford_Six
Nice, looks effective.
I got one of those Harbor Freight manual tire changers, and while it works, it takes some effort with stuck beads.
Old May 20, 2011 | 01:00 PM
monckywrench
You can also sledgehammer the end of the beam over the "shoe", but I haven't had to yet.
Since I am lazy...er, "efficient" I sometimes lift the bead with a tire iron then snip it with the cutting wheel in my 6" angle grinder. Smelly but very fast.
old_dan
47
May 29, 2020 07:02 PM
greenmachinejohn
May 27, 2012 11:15 PM
icemann21
Dec 1, 2011 03:18 PM
dfooch
Aug 10, 2011 10:14 PM
ekbearly
Jul 23, 2010 06:50 PM
