headers
Old Apr 6, 2003 | 07:08 PM
Brian S's Avatar
Brian S
headers
If you are referring to Sanderson, their headers are for the 4V heads but can be used with 2V heads with their adapter plate. The plate isn't needed with Aussie heads. I have a 400 in a '73 LTD that should be the same chassis as a '77 Ranchero. I'll try to eyeball the FC3s to see if there are any interference issues. Remind me if I forget.
Old Apr 7, 2003 | 06:37 PM
dustinleavitt2000's Avatar
dustinleavitt2000
headers
i looked at some headers that were like 100 $ that were shorties. shorties would be an easy isntall right? i am having all new exhaust pipe done so couldnt i jsut have my exhaust guy run the pipe all the way into the compart ment and what problems might i face. i know heat is one but that should nt be bad on a ranchero that has a really large engine compartment
Old Apr 7, 2003 | 08:59 PM
fatdaddy's Avatar
fatdaddy
headers
If ..you can afford them , the sanderson ...ceramic coated headers are the best, short tube headers that you can order thru the mail. One of the first things the instructions from Sandersons will instruct you to do is Get your engine in good running order BEFORE installing your headers...Because(especially with New engines) the Exhaust temperatures are significantly higher during the tuneup process than they are after you get everything running correctly.During the tuneup you should utilize your old exhaust manifolds and THEN install your headers . The higher temp's are very hard on the ceramic coating on the headers. fd
Old Apr 7, 2003 | 09:32 PM
dustinleavitt2000
headers
i cant really afford any 300+ headers if i could i would get the ones from hooker but will universal headers that most companies sell in shorties or block huggers work in a ranchero and will the different deck height from a 351 and a m block make any difference?
Old Apr 8, 2003 | 12:08 AM
Brian S's Avatar
Brian S
headers
Let me know where I can find them.
Old Apr 8, 2003 | 12:16 PM
dustinleavitt2000
headers
SUM-G9036 would headers for a 1986-1995 fit my car?
Old Apr 8, 2003 | 12:21 PM
dustinleavitt2000
headers
HOK-6921 or how about these theyre not shorties but the body style didnt change from 73 to 77 right but the deck height would be different would that matter?
Old Apr 8, 2003 | 02:59 PM
Bill_Beyer's Avatar
Bill_Beyer
headers
The SUM-G9036 pieces will definitely not work. They're for the 351W. The different deck height for the Hooker pieces could be a problem.
Old Apr 8, 2003 | 03:50 PM
dustinleavitt2000
headers
would the c6 transmission be a problem?
Old Apr 8, 2003 | 05:44 PM
Brian S's Avatar
Brian S
headers
You can't use headers for a 302-351W, the exhaust flange is completely different. There's a guy on the Cleveland forum who's running dynomax headers on an LTD. I'll try to get a part number.
Old Apr 8, 2003 | 06:52 PM
dustinleavitt2000
headers
i would greatly appreciate it
Old Apr 9, 2003 | 03:00 AM
Brian S's Avatar
Brian S
headers
This is what JD used for his '72 LTD 400 after minor alterations. order # is 289-85063
http://www.jegs.com/cgi-bin/ncommerc...90&prmenbr=361
$110
Double check with him on the 351C forum.
http://www.network54.com/Hide/Forum/119419
I'm reasonably sure the LTD uses the same chassis as your Ranchero.
Old Apr 9, 2003 | 09:09 AM
  #28
dustinleavitt2000
headers
what kind of modifications?
Old Apr 9, 2003 | 01:27 PM
  #29
Brian S's Avatar
Brian S
headers
Trans filler tube and some hammering on the bell housing. Go to the 351C forum, there's no need for me to keep relaying the info. A guy named Bill had some other input also.
Old Apr 9, 2003 | 10:20 PM
  #30
grclark351's Avatar
grclark351
headers
have we tried calling THORLEY at 909-983-5871?
cassell1
Mar 30, 2015 02:29 PM
351Cleveland C4
Dec 19, 2013 03:59 PM
KFX400
Mar 11, 2007 10:26 AM
wkeller
25
Apr 22, 2006 11:22 PM
dustinleavitt2000
Jun 21, 2003 02:18 PM
