Glue or Duct tape?
Glue or Duct tape?
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if !mso]>******** classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui>*********> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> Hi.
Water got under the F150 badge on my 95s front passenger’s quarter panel, then froze and popped it off. Is that just double sided tape holding it on or did the PO put that on? Anyway what is the best way to reattach? Thank you.
gorilla glue or silicon. I used silicon when i put the SI emblem on my 92 prelude. wouldnt come off for anything.
i say use caulk totally waterproof and you could peel it off if you had to. I used it to re attach some trim on the outside of my cab 2 years ago hasnt moved an inch and it was bent away from the body of the truck
BDB513
Jul 21, 2014 04:38 PM
