unilite distributor
Old May 14, 2011 | 12:33 AM
Ranger GT2's Avatar
Ranger GT2
unilite distributor
Is anyone running a unilite distributor? I have one for my truck but never did put it in. It is the mechanical type. I'm still running the original distributor after the upgrade to headers, 4 barrel intake and 390 cfm holley carb.
Old May 14, 2011 | 08:32 AM
nevrenufhp's Avatar
nevrenufhp
I had ran one on a Cleveland years ago, and it was great. Clean with no misfiring all the way up to 6500. You'll like it. Only thing of caution, they dont like too high of voltage, so make sure you run the OEM resistor wire or a ballast.
Old May 14, 2011 | 08:33 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
The Unilite uses an optical trigger that won't work with the stock ignition module, so you'd need a Mallory box to run it. And no vacuum advance means mileage will take a hit. From an economy standpoint you're better off with what you've got. And unless you're running it flat out all the time probably better off from a performance standpoint as well.
Old May 14, 2011 | 08:56 AM
nevrenufhp's Avatar
nevrenufhp
The optical trigger and module are all inclusive in a Unilite. Just hook up the + & - of the coil & a ground.
Ranger GT2
Sep 23, 2008 03:01 PM
Ranger GT2
Electrical Systems/Wiring
May 12, 2007 12:49 PM
Jims1969F250
Jan 6, 2007 10:54 PM
f700
Nov 8, 2006 04:18 PM
L-N-OR
Sep 6, 2004 09:11 AM
