mallory unilite distributor
Old Nov 8, 2006 | 05:08 AM
f700's Avatar
f700
HI all ford y block nuts , who,s running a mallory unilite distributor ?
and is it good to use ?
Old Nov 8, 2006 | 11:10 AM
bigwin56f100's Avatar
bigwin56f100
I am and I'm very happy with it. I run it in a 56 f100 with a HOT Y. Its a full mechanical distributor, no vacuum advance.
Kevin Bigwin
Old Nov 8, 2006 | 04:18 PM
Homespun91's Avatar
Homespun91
Yep. I've used them before. Two things: 1) They are susceptible to heavy dust & may need to be cleaned every so often (optical trigger). In normal use it's not an issue.
2) They are somewhat famous for being intolerant of wiring mishaps, especially duirng installation. Be very, very careful about the wiring process before you supply it with power. Also, if wiring up anything new, either disconnect the Unilite or pull the neg. battery cable. Supposed to do that anyway, but everybody takes shortcuts. If you buy it Down Under, I'd make sure that they carry replacement modules. No fun to wait on a replacement from the States.
AJHEATING
Jul 26, 2007 06:34 PM
fordhoor
Electrical Systems/Wiring
Mar 14, 2007 11:54 AM
fordhoor
Aftermarket Products
Mar 13, 2007 12:47 PM
Jims1969F250
Jan 6, 2007 10:54 PM
L-N-OR
Sep 6, 2004 09:11 AM
