Bent push rods?
Old May 12, 2011 | 03:42 PM
rolape2's Avatar
rolape2
Bent push rods?
A friend has an 80 F350 with 400M engine. Just replaced timing chain (2 month ago) due to rattle. Now truck is bending push rods. He has replaced a couple twice and it runs good for awhile and then bends them again. Any idea what could cause this? He needs truck bad. It is his living.
Old May 12, 2011 | 03:59 PM
planehunter's Avatar
planehunter
The only way that I can think of any way that he may be bending push rods is if he didn't get the timing marks correctly lined up when he replaced the timing chain. Unless he's racing that motor, or someone did a questionable engine rebuild, it's darn near inpossible to bend a push rod during normal operation. Is he sure he replaced the correct length of push rods? Did he torque everything to the correct specs?
Old May 12, 2011 | 04:06 PM
rolape2's Avatar
rolape2
He says all he did was replace chain. Engine has not been rebuilt. It is an old guy. Uses the truck just for hauling scrap/junk. Doesn't abuse it. I was wondering about push rod length. It did bust 1 of the lifters this time. I am going over in the morning to look at it.
Old May 13, 2011 | 10:56 AM
planehunter
If he damaged a lifter, then the cam is also done. This would indicated he didn't get the timing marks correct. New cam and lifters, new push rods at a minimum. Depending on miles on the engine, maybe time for a rebuild or replacement.
Old May 13, 2011 | 11:30 AM
rolape2's Avatar
rolape2
Yeah I think he needs a new engine just because I know what kind of mileage he has on it. I found a replacement on craigslist for $500 but don't know its condition, says it runs good but you know how that goes. Doin a complete rebuild on the last runs good I bought.
Old May 13, 2011 | 02:20 PM
73FOMO's Avatar
73FOMO
Ditto. Incorrectly installed timing chain. You may even have bent valves now. I would guess entire valvetrain may need replacing...and as planehunter said...depending on miles, either a full rebuild or replacement.
Old May 14, 2011 | 09:15 AM
rolape2's Avatar
rolape2
Found out the first time this happened was 2008. This is 4th time. more valves each time. Only intake valves. He says he has had valve covers off while running and could see valve stick. I am wondering if this could cause push rod to fall out of socket and stick against bottom of rocker, or cause lifter to pump up. Engine has 150,000. 3rd engine, normally gets 300,000 out of an engine. Did notice back of intake valves had excessive carbon build up. Thinking excessive EGR causing carbon that causes valve to stick. EGR is disconnected but that doesn't mean it is not stuck open.
Old May 14, 2011 | 12:38 PM
73FOMO's Avatar
73FOMO
Bent valve causing sticking and bent pushrod is my bet, due to incorrectly installed timing chain. 80% sure.
Old May 15, 2011 | 10:06 AM
deeznuts822's Avatar
deeznuts822
I can't see how someone can incorrectly install a timing chain,You line up two dots.Anyways Id find another motor and be done with it.
DutchmanAZ
24
Jul 28, 2017 08:43 PM
joslawn33
24
Dec 4, 2016 09:09 PM
Torrance00
Large Truck
Sep 16, 2016 11:53 AM
sonny1965
Jun 3, 2016 07:42 AM
popbreed
Oct 18, 2008 09:56 AM
