Bending Push Rods 390 FE
Old May 30, 2016 | 11:27 AM
sonny1965's Avatar
sonny1965
Good Morning Guys
This is what I have
FE 390
was bored 030
crank 010/010
all new valves, springs, valve guides
mild rv camshaft
proformer intake and 600 cfm vac secondaries holley
Drove truck had immediate miss found
bent # 2 exhaust push rod
replaced push rod drove it a little not much at lower rpm,s
bent # 6 intake push tube
Have any ideas where I need to look first?
Thanks
Sonny
Old May 30, 2016 | 03:14 PM
85e150's Avatar
85e150
Springs matched to the cam?
Heads milled or block decked?
Rocker oiling correct?
Old May 30, 2016 | 04:49 PM
sonny1965's Avatar
sonny1965
Will have to get with the machine shop they did both thanks
Old May 31, 2016 | 07:09 AM
69cj's Avatar
69cj
How did you re-install the rocker arms? There is a procedure.
Old May 31, 2016 | 08:33 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
If you reused the old push rods, dollars-to-donuts they are too long after the rebuild.
Sounds like a valve-lash check is in your future.
Old Jun 1, 2016 | 07:15 AM
sonny1965's Avatar
sonny1965
Thanks for all of your help will check valve lash
Old Jun 3, 2016 | 07:38 AM
mark a.'s Avatar
mark a.
Probably a hydro cam so no "lash", his lifters should have preload. You probably will need different length p.r. now because aftermarket cams are likely ground on a different base circle plus all the new parts and machine work that's been done. It has to be checked now.
Old Jun 3, 2016 | 07:42 AM
krewat's Avatar
krewat
You still check the "lash" with hydraulic lifters, there just a much wider range that's acceptable
Fred Case
Mar 26, 2019 10:57 AM
Roger C
Jan 14, 2016 10:02 AM
reifwj
Apr 24, 2008 06:47 PM
highboy390fe
May 14, 2007 12:35 PM
bob arrington
Nov 18, 2003 11:19 AM
