Stallling issue P0605 code
Old May 13, 2011 | 12:35 PM
427 fordman's Avatar
427 fordman
Well, I've been emailing with dptuner, and they said I could try my pcm, just leave it in neutral and see if the throttle response is better. Told me not to put it in gear though. Really happy with the help I'm getting from dp. Guys name is james fwiw.
Old May 13, 2011 | 08:38 PM
F350-6's Avatar
F350-6
I've heard of this before with a Banks set up. Just can't remember what came of it. If it is a 2 part chip/programmer set up, then removing one could easily be the issue. If the chip fell out when the tape was removed, I'd take your chip and plug it in to his PCM. Leave the keys out and don't try to start. Just see if your chip fits better or is also loose. He might need to re-tin the connectors on the PCM to hold the chip in tight.
A loose chip can easily cause a stalling issue.
Old May 14, 2011 | 07:11 AM
427 fordman
Thanks for more knowledge Chris. I'll try what you said, and see what we come up with.
wildstang
Jun 26, 2017 06:09 PM
lordtavo
26
Nov 16, 2015 06:10 PM
xnorp
13
May 1, 2012 05:49 PM
Pocket
16
Oct 25, 2009 11:17 AM
Rory_Johnson
16
May 31, 2009 07:27 AM
