I need help! P0401
Old May 10, 2011 | 09:19 PM
Shanemh's Avatar
Shanemh
I need help! P0401
I have had a DTC coming up on my truck for quite a while now and I have tried to replace and check a number of things in hope that it would go away. The code is P0401.
I have checked and replaced some of my vacuum hoses, changed the plugs, cap and rotor and wires, changed the fuel filter, checked the fuel pressure which is fine, had my injectors cleaned, cleaned my Air mass sensor and still no good.
I did all of the above as I was told any of those could be the culprit.
But no, still getting the code!
Getting very bad fuel economy and truck is idling rough.
Any help much appreciated.
Old May 11, 2011 | 10:26 AM
rla2005's Avatar
rla2005
Why start a new thread on the same issue when you already have an active one going: https://www.ford-trucks.com/forums/1...dtc-p0401.html ?
Old May 12, 2011 | 05:54 PM
Shanemh's Avatar
Shanemh
Thanks, I couldn't find my last thread.
Towzilla
Jul 24, 2021 11:12 AM
97f1504.6black
1997 - 2003 F150
Apr 25, 2014 08:49 PM
judgebc
Jan 4, 2010 12:50 AM
ojosdestranger
1983 - 2012 Ranger & B-Series
13
Dec 15, 2009 09:23 PM
ghardy7605
Oct 14, 2009 07:06 AM
