P0401 Still?
Old May 27, 2006 | 07:08 PM
ojosdestranger's Avatar
ojosdestranger
Question P0401 Still?
2001 | Ranger Edge | 4x4 | Extended Cab | 62K miles | Stock
Go Figure this new one...
Removed neg cable.
Replaced Fuel Filter
Replaced DHCP and EGR valve.
Cleaned ports.
Cleaned Throttle Body.
Still freaken getting the P0401 code and the annoying Check Engine light.
First one to figure this out gets an "All Inclusive" date with my Hot Sister...
-Stranger
Old May 27, 2006 | 07:15 PM
rangerfan's Avatar
rangerfan
We've got to see pics of her sister first. just joking
Old May 27, 2006 | 07:22 PM
ojosdestranger
Her Sister?
Old May 27, 2006 | 07:36 PM
oldgoat49's Avatar
oldgoat49
Are you talking about the DPFE sensor that was replaced? I just replaced mine on my 99 Mazda B3000 today thanks to the info I got from here. Light hasn't come back on but I've also only driven about 30 miles with it also. Also might check for vac leaks and that it is getting vac to the EGR valve and that it is working when Vac is applied.
Old May 30, 2006 | 10:22 AM
ojosdestranger
Yes, the DPFE was replaced...
Light comes on the next day or after 150+ miles.
How do I check if the EGR valve is getting vac? By checking to see if the line that attaches to the top has vacuum?
Old May 31, 2006 | 09:52 AM
Cougar_Vibe's Avatar
Cougar_Vibe
Unhappy
Testing the vacuum on the egr can be done by disconnecting the vacuum line, putting a piece of two foot tubing to the egr, and sucking on it while the truck is running. Mind you, I'm not suggesting this is necessarily the most scientific nor safest way to do it, but it's fairly easy and will give you an indication if the EGR is at least functional (while applying suction, you should hear a change in idle).
BTW: I've been fighting 0401 and 1401 codes for the better part of six months on my 2.5l Ranger too. I've replaced everything but the EGR valve, but after testing it, it seems to be working...so I'm not laying out the $65 for one just yet. I've got about a year to get this thing diagnosed and fixed, else I'll be failing emissions and will have to take it to Ford ($$$). CEL's are very frustrating ;-(
Old May 31, 2006 | 01:32 PM
Piffery1's Avatar
Piffery1
On my '99 one of the ports supplying the DPFE sensor was plugged. To test, remove rubber hoses and start engine. If you can't feel exhaust coming from both ports then one is stopped up (or the orfice between them). I cleared mine by racing the motor with the hoses off. No more annoying check engine light!
Old May 31, 2006 | 02:55 PM
ojosdestranger
Can you please elaborate with detail? Maybe pictures.
If you run with the DPFE off, won't it idle like crazy?
And what do you mean race it?
Old May 31, 2006 | 03:19 PM
Piffery1's Avatar
Piffery1
There is a tube that runs from the exhaust to the EGR Valve. Somewher along it there are two small tubes (ports) attached to it. These are for the two small rubber hoses that go to the sensor. Temporarily detach the hoses and start the engine. You should feel exhaust gas emitting from each. On my engine I could feel none coming from the port nearest the EGR valve so I raced (gunned, VROOM-VROOM, rapidly increased/decreased engine speed) then checked again and exhaust was coming from both ports. Reconnected sensor hoses, reset code and no more check engine light in about 5000 miles.
Old Jun 1, 2006 | 12:43 PM
ojosdestranger
So you didn't race a Chevy truck or anything like that. You just raced the wind... Who won?
I'll look for the two rubber hoses that attach to the exhaust-to-egr tube...
Why not just remove the two hoses and clean them out with a compressor or cleaning fluid?
Old Jun 1, 2006 | 01:37 PM
Piffery1's Avatar
Piffery1
In mine, the rubber hoses weren't stopped up, it was down in the little metal ports (pipes, tubes?) to which the rubber hoses attach or it was in the orfice (inside the large tube). Once I "gunned,raced, whatever" the engine with the hoses removed apparently the exhaust pressure blew out the obstruction. Spray type carburetor cleaner might help, too; but don't get it in the sensor. I assume, in my case, it was exhaust carbon buildup but you may have a totally different problem.
Old Jun 1, 2006 | 04:11 PM
ojosdestranger
Darn... I was already looking for some co-workers to race!
Old Jun 1, 2006 | 04:28 PM
Piffery1's Avatar
Piffery1
Here is a link to a pretty good discussion of how it works: http://autorepair.about.com/cs/generalinfo/l/bl470g.htm It's about an F150 system but applicable to other Fords.
Old Dec 15, 2009 | 09:23 PM
ojosdestranger
Return of the code.
Freaken code returned again! Drove it for months with the CEL till Texas Inspection time forced me to buy an: EGR Solenoid, EGR Pressure Sensor, and finally EGR Valve (Went thru the process of elimination). No more CEL.
jmmranger
28
Oct 14, 2019 10:33 PM
sloate9471
Jul 29, 2016 01:59 AM
mredington
1997 - 2003 F150
Dec 4, 2015 07:23 PM
REGGIE_OBE
1997 - 2003 F150
Oct 16, 2015 06:20 AM
shadyEats
15
May 8, 2007 06:25 AM
