Changing a fuel filler hose
Few years ago I was filling my '77 and gas started running out behind the bed side.
Stopped, looked underneath, squirrels had eaten into the hose connection.
Got a replacement at NAPA, it was longer than needed, you cut it to length. I was able to get old off and new on with aid of vasaline and tightened clamps without raising bed or dropping the tank.
Then I bent up a piece of aluminum and slipped it in place to discourage further squirrel attacks.
So far, squirrels have eaten some tail light wiring insulation between the tails under the tail gate of the '77,
chewed on the new just recently replaced front flexible brake line from frame to axle on the '77 enough to warrant another replacement (I had recently redone the brake lines for the second time since I've owned it),
4" top side fuel vapor hose on my '07 over tank,
nicked the pressure line enough that it leaked,
almost ate through one wire in the harnes for the FPDM of the '07,
nicked a high pressure line on my '92 T-bird,
and I find walnuts in all kinds of places.
I found an intake snorkel and air cleaner box packed full of dry dog food on my '96 Powerstroke a few years ago.................wasnt squirrels.............MICE............little bast**** had been packing the dog food out of the shop and stashing it for winter I guess.......It was so packed in there that the truck would hardly run. Thats how I found it when I started investigating why the truck was running so crappy.
The following users liked this post:
Yeah not sure which way ill go yet my receiver hitch must be a little diff cause its in the way and the exhaust also! That shouldn't be to bad to take off though! Inside of the tank looks prefect outside has rust! Thinking about using that rust killer and just use some rustoleum spray paint or are there better options?
dlogan3762
24
11-03-2016 07:38 PM
19864x4
20
08-18-2016 04:44 PM
