This brings up a question. What is the difference between the ODs on the filler pipes between years?
I ordered a hose from Classic Haulers which turned out to be too small for the pipe(s) I have. On my '51, the ID of the hose has to be 2 1/4" because the fill pipe is 2 1/4" OD. The hose I received had an OD of 2 1/4" so the ID was something like 1 3/4". The CH catalog shows their hose is good for '51-'72. The parts manual shows no diameters for the pipes.
So I wonder if the fill pipe for September '51 and newer trucks are the smaller diameter, or if the CH parts are just wrong.
I think you can guess... You shoulkd have taken the hose I offered at TS! Do you want it?
No thanks Ross. I got the right hose a while back. And IIRC, you sent that hose offer in an email to another Joe... I'll see if I can find that... Yes, on Sept 10. But I forgot all about it with everything that's happened since Truckstock.
