keypad code
Old May 8, 2011 | 05:53 PM
5280NAVI's Avatar
5280NAVI
Nice...maybe I will check the driver side on my 05 to see if I find anything
Old May 9, 2011 | 08:36 AM
alloro's Avatar
alloro
I think it's 04 and up where you'll find it behind the glove box.
Old May 9, 2011 | 09:15 AM
5280NAVI's Avatar
5280NAVI
Yep. Take out the panel for the fuses and look left and up of the fuse box and its right there.
Old May 11, 2011 | 11:01 AM
chicagodragon's Avatar
chicagodragon
anybody know how to reprograme the code?
Old May 11, 2011 | 04:28 PM
alloro's Avatar
alloro
Originally Posted by chicagodragon
anybody know how to reprogram the code?
You can't reprogram that factory code. All you can do is add additional codes as per the instructions in the owner's manual.
Old Sep 16, 2011 | 01:48 PM
Darth_Vukster's Avatar
Darth_Vukster
For my 2004 Expedition the keyless entry keycode is easiest viewed behind the glove box. Open the glove box and pull the two sides of it inwards until the tabs allow you to fold the glove box all the way down (open). Look way in the back towards the front wheel. There is a black box mounted on the outer wall with 3 plugs in it (Grey, Green, and Blue). In sunlight (after your eyes adjust) or with a flashlight you should be able to see a big white sticker with the 5 digit code in relatively big bold numbers. The sticker will be facing the driver side, not towards you, so you may have to get just the right angle or maybe use a mirror (I didn't need one). When you punch the code in, the locks will make a clicking noise confirming it is the correct code. You can then use that code, or add your own.
arrules22
Sep 9, 2016 06:55 AM
Will104
Mar 21, 2016 11:54 AM
ken1509368
Feb 1, 2016 01:11 AM
johnzenobia
2009 - 2014 F150
Apr 27, 2015 11:16 AM
ogbobbyjohnson
1997 - 2003 F150
Feb 11, 2012 09:47 PM
