2002 Explorer keypad
Old Sep 5, 2016 | 11:58 AM
arrules22's Avatar
arrules22
I bought a 2002 explorer a couple years ago and the key less entry code was not given when it was purchased used. I looked up where to find the code behind the passenger side rear door seat belt panel. However the keypad will not work. The lights come on and when the bottom two buttons are pressed the doors will lock, so the keypad clearly works however the numbers I have gotten are not working. Has anyone had this problem and knows how to fix it? I'd rather not take it to the manufacturer due to they will charge me an arm and a leg for it.
Thanks
Old Sep 8, 2016 | 11:25 AM
Stewart_H's Avatar
Stewart_H
Welcome to FTE.
I moved your thread to the correct forum to get you the help you're looking for.
Stewart
Old Sep 9, 2016 | 06:55 AM
shorod's Avatar
shorod
Are you sure you read off the correct 5-digit code?
About the only other option I'm aware of would be to find a shop or friend with a professional scan tool, access the security module, and read off the 5-digit code from the scan tool.
-Rod
Melissagb43
Mar 3, 2019 07:26 AM
bronco549
Oct 10, 2016 09:19 AM
Paul_Heckel
Mar 28, 2015 09:50 PM
03eeb
Apr 15, 2005 10:19 PM
