body work advice
Old May 6, 2011 | 08:59 PM
zombiefied 247's Avatar
zombiefied 247
body work advice
i am doing the dismantle on my 55 f100 and came upon a question. the previous owner decided to mold the front fenders in with body putty therefore it is all cracking from body flex etc. is it better to try and grind this out with a grinder or try to sand it out?????
Old May 6, 2011 | 09:09 PM
sdetweil's Avatar
sdetweil
You want to make them separate after you finish? Then u need to sand. A disc on your grinder can speed things along.
Sam
moose79's Avatar
moose79
i would sugest sandblaster, putty doesnt stand a chance
Old May 6, 2011 | 10:21 PM
52 Merc's Avatar
52 Merc
For major bondo removal, an 8" pad like this one in the link below on a buffer or grinder and some 36 or 40 grit sandpaper will knock it right down real quick. It's the best way to go, imho, and it should be available locally, along with the sandpaper you need at a body shop supply store. Sandblasting runs the risk of making too much heat and warping the panels.
3M 05579 Stikit 8" Air disc Pad
Old May 6, 2011 | 10:29 PM
lexcoe's Avatar
lexcoe
If you have a heat gun it takes it out easily, and no grinding. Try it, it works......
John
Old May 6, 2011 | 10:41 PM
SCRAPHEAP51's Avatar
SCRAPHEAP51
Lots of good advise so I will through in one more, I use a brush on chemical stripper from walmart that soften the bondo up pretty well and used a putty knife to remove, though it is messy and you will need to make sure you clean up the area very well before reappling primer.
Old May 7, 2011 | 01:36 AM
iwanaflattie's Avatar
iwanaflattie
I used a 4" wire wheel on a grinder not the home depot wire wheel,it was a good ol made in the usa-coarse wheel and it cleaned 1/4" thick bondo in 2 minutes.
Old May 7, 2011 | 01:58 AM
POS-F500's Avatar
POS-F500
If it's just plastic filler, my preferred method is chipping it off in chunks with a putty knife and a small hammer.
I started this on the roof of my 56... Whole skin and gutters were coated in a thick coat of...
Oh, it wasn't plastic filler (aka Bondo, etc) it is FIBERGLASS resin. That stuff is a real.. 'whoot' to remove. It started taking the metal with it.
Old May 7, 2011 | 02:49 AM
Randy Jack's Avatar
Randy Jack
My vote is the wire brush on an angle grinder. I did all the bodywork on my 56 and nothing works faster or better. DO NOT USE ANY CHEMICALS! They stay in the seams and mess up your paint later.
HINT: do it outside where you can wash all the debris away or you'll be finding bondo dust on everything for years. Wear coveralls, if you have them.
Good luck.
Old May 7, 2011 | 03:59 AM
iwanaflattie
Good luck.
Totally agree.Also wear thick clothing and goggles them little wires fly so fast you dont want them in your eyes.
Last time I wire wheeled wires got my crotch.
Old May 8, 2011 | 06:49 AM
POS-F500's Avatar
POS-F500
Originally Posted by iwanaflattie
....Last time I wire wheeled wires got my crotch.
Did you feel a tiny *****?
Old May 8, 2011 | 06:56 AM
iwanaflattie
no it was huuuuge .
racer2012
Oct 23, 2012 04:43 PM
mudder460
Jun 21, 2009 01:36 PM
ga73f100
Oct 29, 2006 06:46 PM
fastfrd2
Appearance & Dress-Up
Feb 13, 2005 11:09 AM
gquinn8516
Dec 19, 2002 11:03 AM
