Body mount help!!
Old Jun 10, 2009 | 10:11 PM
mudder460's Avatar
mudder460
Body mount help!!
I have been racking my brain trying to get this figured out for my truck. I ordered these body mounts: Body Mount Bushings, Pick-Up, Red but now I am in need of the sleeves. I have been looking but there are some lower sleeves with a small dia. Body Mount Sleeve, Smaller Dia. Lower and a larger dia. Body Mount Sleeve, Large Lower They are numberd for positions they go in but what are the positions on the truck? I was looking at the upper sleeve and it says for position 2, where are the rest of the sleeves I will need? Can anyone help me out with this problem?
Old Jun 10, 2009 | 10:16 PM
hp246's Avatar
hp246
If there are two smaller sleeves, and the rest are larger, the two smaller lower sleeves fit the radiator support. The bushings should fit the same way. The two smaller bushings for the radiator support, and the rest for the other mounting points.
Old Jun 10, 2009 | 10:17 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I don't know the direct answer, however...
I would tend to think position:
1 is the radiator core
2 is forward body mount
3 rear body mount
and then so on for the bed...
Old Jun 10, 2009 | 10:20 PM
mudder460's Avatar
mudder460
3 rear body mount
That is what I thought it would be, but like you I am unsure and don't want to order anything before I am sure!
Old Jun 10, 2009 | 10:41 PM
mudder460's Avatar
mudder460
Another question I have is, since the bushings I bought have a sleeve built into them do I even need the upper sleeve? Or can I get away with just ordering the lower sleeves?
Old Jun 14, 2009 | 10:18 AM
Hyperactive460's Avatar
Hyperactive460
when i installed my new body bushings i went to ford and baught just the lower sleaves ( basicly a large washer with a nut and sleave welded to it ) smaller ones for the radiater and the others for the cab itself.
Old Jun 14, 2009 | 04:00 PM
mudder460's Avatar
mudder460
What did that cost you buying from Ford?
Old Jun 21, 2009 | 01:36 PM
Hyperactive460
i can't remember, not even sure if thier available anymore. best thing to do is check with your local ford dealer.
mudder460
24
May 4, 2018 06:36 AM
jaspirr
27
Aug 5, 2015 08:44 PM
Thunderhorn
1978 - 1996 Big Bronco
May 1, 2014 08:18 PM
Aksel Bourdages
Jan 30, 2012 01:28 AM
david00f150
13
Sep 5, 2009 04:15 PM
