1978 - 1996 Big Bronco
Shifting problems
Old May 1, 2011 | 08:40 PM
Jesse1989's Avatar
Jesse1989
Question Shifting problems
I have a 1990 5.8 4x4. The truck does not like to go into OD and wont shift past second gear. The fluid looks good, but I know nothing about transmissions. Please help. Thank you in advance.
Old May 1, 2011 | 11:32 PM
greystreak92's Avatar
greystreak92
My suggestion would be to pull Codes. The control for the E4OD is completely electronic and often malfunctions will trigger fault codes. This helps pinpoint the root of the problem.
Old May 2, 2011 | 08:55 PM
b4hntn's Avatar
b4hntn
Codes are your starting point. With a warm engine get codes from the three areas KOEO, CM, KOER.
Old May 4, 2011 | 12:25 AM
Jesse1989's Avatar
Jesse1989
No codes
I checked for codes a while ago when the check engine light was on but the codes had nothing to do with the transmission. The light is not on now so I am not getting a reading.
Old May 4, 2011 | 06:13 AM
b4hntn's Avatar
b4hntn
Transmission shifting is also a function of engine codes. We have to have a happy engine to have a happy shifting transmission. We can have diagnostic codes even if the check engine light is not on, especially in continuous memory (CM).
You said "The light is not on now so I am not getting a reading. " Are you getting either 11 or 111 passed codes in all three areas, KOEO,CM, KOER ?
FYI, in case you have not seen it save this as favorite Ford Fuel Injection
kupiec20
Dec 13, 2009 09:01 AM
EaTmYtAiLpIpEs
Dec 14, 2008 07:40 AM
73f1004x4
Dec 19, 2007 07:10 PM
glong15650
Aug 23, 2006 09:40 PM
Sliver Doug
2004 - 2008 F150
Jul 31, 2005 11:46 AM
