hard down shift
Old Dec 12, 2009 | 09:24 PM
kupiec20's Avatar
kupiec20
hard down shift
i have an automatic trany that has been very well maintained since birth-
when i accelerate it shifts perfect but when it down shifts from 4 - 3 it shifts hard and then its smooth the rest of the way.
any ideas?
Old Dec 12, 2009 | 09:26 PM
Gale Hawkins's Avatar
Gale Hawkins
Has it just started this?
Old Dec 12, 2009 | 09:33 PM
kupiec20's Avatar
kupiec20
not really its been going on for about 3 months, why whats up?
Old Dec 12, 2009 | 09:36 PM
kupiec20's Avatar
kupiec20
if i shut the OD switch off then it never gets to the highest gear and everything will shift smooth
Old Dec 12, 2009 | 09:49 PM
Gale Hawkins
Just a guess since it just recently started it after all of these years you have some wear at some point. Not sure the miles on the fluid but a total bucket flush with synthetic ATF would be my first step I think. It as seen a lot of action over the years with more than the amount of factory HP in front of it I gather from your signature.
If it does not go away with fluid exchange it may just be something to adjust too. At least you can keep ir from down shifting under a lot of power or kept it out of OD when on roads where it normally shifts in and out of OD.
After buying a new transmission I keep the new one out of OD on some secondary roads due to advice from the transmission shop.
I see you posted about OD use while I was typing and figured out a work around which is good to know how to do when our equipment gets some age on it. We farmed with worn out equipment but we did not loan it to others.
Old Dec 12, 2009 | 10:40 PM
c00nhunterjoe's Avatar
c00nhunterjoe
my first question is what kind of shift kit is in it? the 4-3 downgear harshness could be the way fluid is channeled to the clutch coupled to the reactivation of the torque converter clutch
Old Dec 13, 2009 | 04:14 AM
kupiec20's Avatar
kupiec20
the kit was done years ago by using shims i think, does that make any sense!
Old Dec 13, 2009 | 09:01 AM
MADVAN's Avatar
MADVAN
Remove the php and retest.
Your 14.7 mod is removed with the php?
Bill
scrobbie
Jan 18, 2014 06:12 PM
trevorcapps
1997 - 2003 F150
Feb 21, 2013 08:04 PM
hbonham
Jun 27, 2007 12:13 AM
samkirk1
Computer Chips & Tuners
Dec 3, 2003 09:05 AM
rbtnt
Oct 29, 2001 11:11 PM
