Changing 4spd. shifting point..??
Old Jul 31, 2005 | 10:36 AM
Sliver Doug's Avatar
Sliver Doug
Question Changing 4spd. shifting point..??
my 2005 FX4 shifts into 4th around 45/50 mph.. I would like It to shift at 40/45... can the shifting point be changed...??
Old Jul 31, 2005 | 10:46 AM
ChrisAdams's Avatar
ChrisAdams
Not sure what you mean. On my truck it drops into overdrive at about 40 if I am using light throttle. If I back out enough on the throttle it will shift into fourth lower still.
It's a factor of load vs mph. If it goes into OD (with the TC locked up) too early it can be very hard on the components, and not good on driveability, as it will shudder and buck.
That said, with a tuner like the Diablo Preditor, you can lower your shift RPM at WOT, which makes it shift into gear a little bit lower in the whole range.
Chris
Old Jul 31, 2005 | 11:46 AM
WhëëlMå1's Avatar
WhëëlMå1
You can change shift points with an aftermarket tuner as far as I know.
nickmobile67
1983 - 2012 Ranger & B-Series
Dec 19, 2014 05:27 PM
polar888
2004 - 2008 F150
Jul 9, 2011 03:08 PM
stvsr1
18
Mar 9, 2005 01:41 PM
Redone
Aug 10, 2003 01:37 PM
