motor comming out
Old Apr 26, 2011 | 10:54 PM
axel 56's Avatar
axel 56
motor comming out
It should be out tomoro . But the eng is siezed solid so I cannot unbolt the tourq converter from the flex plate will this be a problem I am not all that savy on automatics will the eng pull away from the trans with the converter still bolted to the flex plate ?
Old Apr 26, 2011 | 10:57 PM
oreocreaming's Avatar
oreocreaming
not too much of a problem. you will unbolt the 6 bolts from the bellhousing to the block, drop your driveline, unbolt your transmission cross member and slide the tranny back enough for the torque converter to slip off the transmission input shaft. maybe 6" or so. then you will have access all the way around it. just be ready for it to pour some atf outta there.
Old Apr 26, 2011 | 11:17 PM
axel 56's Avatar
axel 56
Thanks its a 4x4 and yeah I figuered it would be messy is there any wireing or shift linkage i need to be wary of
Old Apr 27, 2011 | 08:38 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Both, and a few vaccum lines to boot im pretty sure.
Old Apr 28, 2011 | 07:59 PM
axel 56's Avatar
axel 56
Well its out did not have to drop crossmember on trans and slide trans and t case back . Did have to unbolt trans from cross member and put block of wood under it with a floor jack disconenct shift linkeage from trans and tcase then lift eng and jack trans at same time take oil filter off it helps LOL then wen eng seperates from trans remove tourqconverter to get the eng the rest of way out. You need every thing off the front of eng makes life way easyer .
Brant Bowrifle
Sep 10, 2023 10:10 PM
ffflash480
Feb 20, 2013 01:34 AM
meierw1
Jul 29, 2011 03:01 PM
Firetrout
Jul 26, 2011 05:17 PM
tbud
Bronco II
Dec 31, 2003 03:11 PM
