Power steering conversion 66 F100
Old Apr 26, 2011 | 06:52 PM
superbean's Avatar
superbean
Obviously I will need a power steering box, high pressure hose, return hose, pump, brackets, belt and resivoir.
The motor is an fe so any fe based brackets will work.. but from which years can I use the power steering box and lines? Is there any modification needed to be done to use my existing steering column?
All help is appreciated.
Old Apr 26, 2011 | 07:47 PM
OldHarley's Avatar
OldHarley
Oh yeah, Beany-boy.
First, more info. Are you going Bendix as original, or the later Ford Saginaw box? Do you have an auto, 3 or 4 speed?
If you use the later Ford box as I suspect, you will need several additional column parts if you choose to return things to looking original.
Let us know what you have and we can be of more help. Also use the search feature, there are articles on the swap.
Old Apr 26, 2011 | 07:51 PM
Confederate Diesel's Avatar
Confederate Diesel
Double post
Old Apr 26, 2011 | 07:53 PM
Confederate Diesel
Um, not quite. There is no "standard" or single set of FE brackets. I know from experience of at least 6 different pulley/bracket arrangements for FEs - and little was the same between them. You would be well advised to harvest a complete pulley and bracket setup from an FE that has everything you want. Don't forget A/C, because even if you do not want it now, you will have to replace the whole setup to get A/C if all you get now is a P/S setup only.
..but from which years can I use the power steering box and lines?
Look for the PS box, brackets, pulleys and all from '70 - 79 trucks. It all bolts up.
Your steering column will have to be shortened. For a 3-on-the-tree, this is difficult. For an automatic, it is much easier to use '68-'72 column, which bolts up, but it isn't original. Another option is to use a very, very rare '73 - '79 3-speed manual shift column for power steering, or use one from the same years for automatics. If you have a 4-speed on the floor, you can easily shorten your existing column.
Use the search function for more information, especially on the Bendix option mentioned by Greg - but it is one most consider to be inferior, unless you are doing a correct restoration or upgrade.
Old Apr 28, 2011 | 03:44 PM
rustywheel68's Avatar
rustywheel68
if you have a 3-on-the-tree, this is a good time to think about switching to a floor shift.
in the 67-72 trucks, the motor mount perches are different between p/s and non p/s trucks, but i've never done this swap in a '66, so i don't know if that applies here.
Old Apr 28, 2011 | 09:42 PM
superbean's Avatar
superbean
Originally Posted by RocketMonkey28
I have a couple of 67 up power boxes, and at least one column. I'm not sure about pump/brackets, though. I can check. I'm in Vegas, I work at Nevada Pic-A-Part. I'll help with any parts or info I can.
PM me with a price on a power steering box. I think i have located a bracket and pump and i work at a parts store so the misc lines and all will be easy to obtain.
Originally Posted by OldHarley
Oh yeah, Beany-boy.
Truck is 3 speed floor shift
Doesn't matter to me as long as it works
Floor shifter already
Old Apr 28, 2011 | 10:00 PM
Confederate Diesel
This is correct.
The Bendix PS box was used to middle or so of '69. NumberDummy has posted the exact VIN of the changeover.
The Ford box replaced it, and was used up to '79. I have had both, and prefer by far the Ford box.
If you use the Bendix, you do not need to change either the motor mounts or the steering column.
If you use the Ford steering box, you must change the driver's side engine perch (or cut it) AND you will have to eliminate the heat riser valve under the driver's side exhaust manifold.
It was these changes that prompted me to use the Bendix box at first, but after all was said done, I wished I had followed others' advice and made the changes and gone with the Ford box. Go to the trouble to make the exhaust changes and all, and you will be much further ahead.
Old Apr 28, 2011 | 10:41 PM
jhooch's Avatar
jhooch
If you do indeed use the Bendix box, you will need the steering shaft out of a column (or shorten yours) from a 66-early 69 power steering truck. I simply took the shaft from a 68 power steering trucks column and installed it in my '66 column. Otherwise your steering wheel will sit about an inch away from the column.
Old May 15, 2011 | 08:26 PM
Oldschool1962's Avatar
Oldschool1962
New Oldbie
I see something mentioned about brackets and there being different ones for engines even the same line of them. I have an in-line 300 and need to know what bracket to use for my conversion. Would the bracket off of any 300 work? I'm not worried about A/C since I am 100% positive the truck will never have it added by me and I'm not worried what happens if and when I ever sell it.
Thanks
Old May 15, 2011 | 10:08 PM
my 66's Avatar
my 66
what if
i am getting a power steering box off a 76 and the motor mounts off the same truck for my 302 , will i need to alter the drivers side mount also. thank for any imfo.
Old May 16, 2011 | 07:56 AM
rustywheel68
get the driver's-side perch as well, and you should be all set.
Old May 16, 2011 | 07:08 PM
BigMikeUGA's Avatar
BigMikeUGA
I'm getting ready to do the swap in my '65 (352 4sp).
My buddy gave me everything I needed to do it when I bought the truck from him. Everything came out of a '71.
FoMoCo Pump and brackets
Motor Mount Perch
Steering column setup for an automatic (I'm changing the collar from my column)
Steering gear
Hoses
Cooler
I'll be documenting the installation with pictures in the next few weeks. I'm buying a new/reman steering gear and pump and using the old stuff as cores. I don't want to go through all of the trouble of the install and have to change it out soon.
Old Jul 21, 2011 | 08:00 PM
The Masked Rider's Avatar
The Masked Rider
Jeff is correct. switching to a Bendix box, your steering wheel will set around 1" closer to your body. Those going with the later PS box, will find that steering wheel about 3" closer to you. I found this out when I installed the later ford box years ago. I ended up removing my column and cutting 3" out of the middle of it and welding it all back together. Works perfect for me. If I had to do it over, I might have even cut out 4". Make up for this expanding front end I find growing on me. :O( Gives ya a whole lot more room in front of ya.
Fritz
Old Jul 21, 2011 | 09:30 PM
Broomfieldbum's Avatar
Broomfieldbum
I am so glad this popped up today. I am having to rebuild my column, and replace the steering gear. So this is an opportune time to look at possibly putting power steering in. I have a 240 6 Cylinder, and a 3 speed on the column, and I want to keep both. Given a choice of losing the 3 on the tree for power steering would not be a choice I would take. I'll keep the manual steering, to keep the 3 on the tree.
I am considering going to a pick a part place and buying all the brackets, pump, and pulley. Then getting the rebuilt Gear, replacement pump, and new hoses.
Will this work?? Is this going to effect my column? Would trading out the rag joint for a universal joint change things at all??
Old Jul 22, 2011 | 08:36 AM
rustywheel68
my understanding is that to keep the 3-on-the-tree, you'll have to use the Bendix box. they're harder to find than the Ford box. and you'll need to shorten your existing steering shaft, or find one from a late 60's power steering truck that had the Bendix box to begin with (details on this a few posts up.)
i can't swear by this, as i wasn't keeping the column shifter when i did my swap.
66v8baby
Feb 24, 2017 07:46 PM
treverd
Jan 9, 2017 09:23 PM
Jacks 65
19
Aug 10, 2016 09:30 PM
Damifiknow
Aug 5, 2016 09:46 AM
Don Vito
19
Jul 11, 2016 11:50 AM
