300ci power steering pump brackets
Old Mar 6, 2012 | 12:49 PM
Jacks 65's Avatar
Jacks 65
I am in need of the power steering pump brackets for a 300ci...I have a pump and steering box from a '79, I need this to add power steering to my '65 F-100...any help would be awesome!
Thanks
Phil
Old Mar 6, 2012 | 03:22 PM
mikeo0o0o0's Avatar
mikeo0o0o0
There are two parts you need:
Support, p/s pump
Fits: 78-up F100-350 w/ 6 cyl
D8TZ-3C511-A
Dennis Carpenter, Concord, NC has 1 (704) 786-8139
Bracket, p/s pump adjusting
Fits: 78-up F100-350 w 6 cyl
D8TZ-3A732-B
Green Sales, Cincinnati, OH has 2 (800) 543-4959
Old Mar 6, 2012 | 06:32 PM
fordman75's Avatar
fordman75
Shoot me a PM I've got the parts you need on my 78 F150.
Old Mar 7, 2012 | 12:21 AM
Jacks 65's Avatar
Jacks 65
Mike thanks for the help!
And Ted PM sent...
Old Oct 5, 2012 | 09:36 AM
bajafishnut's Avatar
bajafishnut
Hello Fordman 75
I am wanting to convert my '67/72 Highboy to power steering, and have been gathering most of the stuff... need to find the power steering pump bracket for my 300 inline. With that, and the hoses, I should have everything to do the job..
Any help you guys can be, I'd sure appreciate it...
bajafishnut
Old Oct 5, 2012 | 09:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Which P/S pump are you using? 1965/77 w/a steel reservoir, or 1978/79 w/a plastic reservoir?
The P/S pressure hose and the mounting brackets are specific to each type.
Old Oct 5, 2012 | 11:50 AM
fordman75's Avatar
fordman75
Hello Fordman 75
bajafishnut
Sorry I've only got one left and it's a serpentine saginaw set up out of a late 80's van. I'm using that one in my 54 project.
Old Oct 6, 2012 | 05:26 AM
bajafishnut
Highboy power steering project
Thanks for the information guys, and to number dummy, I do not have the power steering pump yet, but have located, and am about to purchase the bracket # D8TZ-3A732-B... found it new for $55..+ shipping... now looking for the D8TZ-3C511A to go with it... Which pump do these brackets support? I will buy the pump new also, as my Highboy is about 1000 miles south of the border, and that's a long way to go for another..
Old Oct 6, 2012 | 05:35 AM
bajafishnut
Power steering brackets?
I have just re-read the posts about power steering pump brackets, and think that I may be trying to buy the brackets for the later model plastic pump. Anybody have any experience with the plastic vs steel pumps? Any preference?
Old Oct 6, 2012 | 06:17 AM
NumberDummy
D8TZ-3A732-B .. Plastic Reservoir P/S Pump Adjusting Bracket / Obsolete / 1978/79 F100/350 300 I-6.
D8TZ-3C511-A .. Plastic Reservoir P/S Pump Support Bracket / Obsolete = No Ford Dealer or obsolete parts vendor has any* / 1978/79 F100/350 300 I-6.
Plastic reservoir mounting brackets will not work w/the steel reservoir pumps because plastic reservoir pump is a different shape and smaller in diameter.
P/S pressure hoses used with the plastic reservoir pump have a straight tube with an o-ring at the pump end. Connects to the pump using a qwik connect fitting.
1965/77 steel reservoir pump: P/S pressure hoses thread onto the pump.
* Post #2: Mike located (1) D8TZ-3C511-A at Dennis Carpenter, but post #2 was typed exactly 7 months ago (03/06/2012).
Once obsolete part numbers and their sources are posted on FTE by Mike and I, they tend to be gone within a very short time.
And, Green Sales no longer has the (2) D8TZ-3A732-B brackets that are listed in this same post. As of 10/06/2012, no Ford Dealer or obsolete parts vendor has any.
Old Oct 6, 2012 | 10:02 AM
bajafishnut
Thanks Number Dummy
I found one of the 3A732-B's , new still in the box.. and will buy it today, so I guess that commits me to the plastic version.. maybe better anyway, if its smaller. ie, more room.. Once I'm committed to that bracket, I guess I will make the other one, best I can, from the Fordification parts schematic.. unless, my amigos find a donor truck in Baja.. Until recently, that was a parts graveyard paradise, but with the price of steel going up, I see trucks every week, loaded with mashed old cars.. the donor trucks are disappearing quickly..
Old Oct 9, 2012 | 09:18 AM
bajafishnut
300 P/S pump brackets
OK amigos,
I found, and have ordered the front mount bracket for the P/S plastic tank pump... anyone out there know where I can find the other (adjusting), bracket? need a little help here...
Thanks
russ
Old Aug 10, 2016 | 03:00 PM
twofifty's Avatar
twofifty
Hey Guys,
Digging this one up from the grave, hopefully someone on here has what I'm looking for. I'm trying to track down power steering brackets for my '79 F250 with 300 Inline 6 (like everyone else in this thread).
Here are my questions:
Are the power steering brackets listed earlier in this thread the same for 2wd and 4x4 trucks?
These are the part numbers listed earlier by NumberDummy:
Neither of those specify whether 2wd or 4x4. I know the steering box is different, but didn't know if the pump and brackets would be the same or not.
Does anyone have a couple good photos of their power steering brackets on a '78-79 Inline 6 truck?
I have a line on one locally, but want to make sure it doesn't have to be from a specific model beyond being a plastic pump with the 6 cylinder brackets.
Thanks, Jim
Old Aug 10, 2016 | 03:16 PM
bajafishnut
Both ND (Number Dummy), and Jefffafa (El Rey), helped me locate brackets for my 300 IL 6. It was suggested to me, to use the Saginaw, 'canned ham' style pump, that was used in the Econolines, and on the 300's.. ND posted locations of 3 dealers who still had pump brackets, and all 3 agreed to send them to a dealer in San Diego for me. You might want to pm them both, as both are over the top helpful, and way beyond the book knowledgeable with obsolete parts...
Baja
Old Aug 10, 2016 | 03:58 PM
twofifty's Avatar
twofifty
Baja,
Do you have a photo of your finished setup that you'd be willing to post?
What was the benefit of going to the Saginaw pump over the 78/79 style plastic pump?
I see that FordMan75 mentioned earlier that his is a serpentine setup, is that what yours is too or are earlier models still v-belts on the Saginaw?
