new IP pump
Old Apr 26, 2011 | 03:25 PM
IDI Diesel's Avatar
IDI Diesel
Question new IP pump
So when i did my engine swap last winter the old engine had a new raman. IP pump that i removed. I havnt used it yet but I know it works. I wasnt sure how to store it so I just placed it on the shelf. No bag or anything around it. Its in my barn but in a place with out any dust or small particles. I plan on intstalling it this summer. Is theere anyway i should prep it for install? I know it would have been better to put in feul/oil mix but to late now. Its been sitting there for just over a year now.
Old Apr 26, 2011 | 03:44 PM
1bigjoe's Avatar
1bigjoe
take the top off fill with sea foam ,
put top back on,
spin by hand ,
install
Old Apr 26, 2011 | 03:48 PM
IDI Diesel's Avatar
IDI Diesel
what do you mean the top? could i just turn it over and fill with sea foam where the drive gear is exposed? it was unbolted by the 2 or 3 bolts above the water pump. So i guess the entire drive gears and bak part where the injector lines branch off are one piece right now.
Old Apr 26, 2011 | 05:03 PM
snaponprofile's Avatar
snaponprofile
Don't take the top off unless you know what you are doing. If put back wrong it will run away on ya.
Old Apr 26, 2011 | 06:57 PM
tecgod13's Avatar
tecgod13
What do you mean about the drive gear exposed? Did you pull the gear cover/oil fill with the pump attached? And the drive gear is really a gear thats sticking out the bottom?
Remove the cover from the front, its two 1/2" bolts. Under there you will see 3 - 12 point bolts, remove with 5/16" socket. Pull the pump out from the gear cover. Thats how its supposed to be removed. DO NOT take the gear cover off your current motor, moving that drive gear will screw the timing, and its not so easy to get the gear back in the right spot without removing the front cover of the motor.
The pump should be fine just sitting if you had been using good fuel before. However, dust and other particles could get into the fittings that lead to the injectors. Those particles can mess up the injectors. If you don't want to take the top off, you should be able to pour fuel either into the outlet at the top of the pump, or stand it on end and pour into the large fitting at the end of the pump, thats the fuel inlet. Then turn the pump over by hand to pump clean fuel out all of the injector fittings and flush any particles out of them. Then cover all the fittings until you have it installed.
Old Apr 26, 2011 | 07:16 PM
IDI Diesel's Avatar
IDI Diesel
Im not home or id take a picture to show you. I unbolted the assebmly with two bolts going into the water pump. The whole assembly i removed has the oil filler neck, pump and lines. The gear sticking out the bottom is a cross tooth gear about in inch wide and maybe 5" round. Than behind that filler neck housing is the actual pump? I didnt remove any covers.
Old Apr 26, 2011 | 07:21 PM
snaponprofile
Oh boy, thats not good news. You are only supposed to remover the IP itself, not all the timing gears too.
Old Apr 26, 2011 | 07:33 PM
IDI Diesel's Avatar
IDI Diesel
wht can i do since it already is removed? any way to still use it or is it garbage now?
Old Apr 26, 2011 | 07:52 PM
tecgod13's Avatar
tecgod13
The pump is still fine. You just removed the drive gear, and the drive gear cover with oil fill in the process. Since that was an old engine you're no longer using, who cares??
BUT, if you go to swap it DON"T TAKE THE OFF THE RUNNING ENGINE! Thats what we're saying.
I can't really find a good picture to show you what we're talking about, but look here:
Ford Questions - Ford F350 SuperDuty Pickup 4x4 Im putting a new injection - JustAnswer
Old Apr 26, 2011 | 07:55 PM
snaponprofile
Ya, you can still use the IP, what tec said.
Old Apr 26, 2011 | 08:08 PM
IDI Diesel's Avatar
IDI Diesel
ok i definatly wont take the filler neck off the running engine!! thanks guys
119er
Jul 18, 2013 07:29 PM
hairyboxnoogle
Sep 12, 2011 09:16 PM
deceptichop
Feb 27, 2011 07:52 AM
tuppence
Nov 1, 2008 08:01 PM
Hamberger
Jan 3, 2007 02:37 PM
