Power Steering Problem
Old May 26, 2011 | 09:36 AM
TAT2DUP81's Avatar
TAT2DUP81
Well I got 06 f350 drw 4x4 so just checking out any precautions I may need to look out for
Old May 26, 2011 | 09:39 AM
bpounds's Avatar
bpounds
An '06 should have the zerks, and you definitely want to give them a shot of lube. I do it every other oil change. They are often missed because they are the only zerks on the whole front end. Probably on the whole truck.
Old May 26, 2011 | 09:49 AM
TAT2DUP81's Avatar
TAT2DUP81
Ok thanks. Yeah took to a lube spot and they didn't find em
Old May 26, 2011 | 10:41 AM
StevensPoint's Avatar
StevensPoint
Originally Posted by TAT2DUP81
Can u post pic of where u greased please?
bpounds is right - that's the zerk. A couple years ago I crawled around under there looking for anything that could be greased and found nothing. After I started having the steering problem I was told that an '06 should have zerks on the front outer u-joints. I turned the wheels all the way to one side and crawled under - still could not see them, but after I cleaned the gunk I could feel them on the back side. I put it in 4WD and backed up 1 foot then the zerks were facing me and could easily be greased.
BGDDYKWL
Mar 3, 2017 09:35 AM
Dezl Newbie
13
Dec 27, 2016 03:19 PM
Galen717
Jul 31, 2016 11:33 AM
underthesun
Mar 20, 2016 02:25 PM
cajun_driller
6.7L Power Stroke Diesel
Mar 16, 2014 07:30 PM
