Power Steering Problem
Old Apr 25, 2011 | 03:38 PM
StevensPoint's Avatar
StevensPoint
Hi All-
I've been having some steering problems lately. About 90% of the time it works fine. The rest of the time I am fighting it - kind of.
When I am having problems with it what I notice is that it doesn't want to straighten out. For example: after a turn I have to physically crank the wheel back to center and then I have to turn about 45 Deg. past center to go straight. After a short while the problem corrects and then I am shooting off in the direction that I was pulling the wheel toward. Sometimes I'll be going in a straight line at hwy speed and it suddenly veers off to one side. I have to fight it back to center and after a little while it corrects and I'm veering in the opposite direction again.
When I am fighting it - it's not like the power steering is completely gone, just diminished a little. The pwr steering pump does not appear to be making any noise. Although if you listen real carefully while turning the wheel at a full stop you can hear a slight whining.
I did do a power steering flush per directions that I found on the internet using Mobil 1 synthetic ATF fluid. This did not help the problem.
Any help is appreciated.
Old Apr 28, 2011 | 10:01 AM
Bkiggins's Avatar
Bkiggins
My brother is having the same problem with his 06 F350 cc still trying to track it down. Let me know what you have tracked down.
Old Apr 28, 2011 | 10:58 AM
rdunagan's Avatar
rdunagan
if its a gearbox get a red head gear box! im about to get one because my box is leaking
Old Apr 28, 2011 | 11:08 AM
steelhead2's Avatar
steelhead2
Sounds like your steer box is failing internally.I would check the front end real good to,from tie rods to ball joints.
Old Apr 28, 2011 | 03:35 PM
StevensPoint
Turns out it is the u-joints at the wheels. They are binding and that it what is causing the hard steering. That's no cheap fix either.
Old Apr 28, 2011 | 05:22 PM
bpounds's Avatar
bpounds
On an '06 you should have zerks in those U-joints. Have you tried pumping in some grease while turning and working it in? Chances are it is too late for that, but definitely worth a try.
Jack up the front, turn the steering wheel hard to one side (doesn't matter which side), inject some grease, turn the tire/wheel a few, then pump some more. Turning the wheels hard to one side forces maximum articulation of the U-joint while the grease enters the needles.
Old Apr 28, 2011 | 06:43 PM
69cj's Avatar
69cj
Agreed just don't hold it lock to lock till it sqeals. Good way to wipe out a pump or gear box.
Old Apr 28, 2011 | 06:52 PM
bpounds's Avatar
bpounds
Good point. I didn't mention it, but you don't need the engine running to do this. If you take the time to jack up the front.
Old Apr 28, 2011 | 07:14 PM
StevensPoint
Thanks - I'll give it a try and report back.
Old Apr 28, 2011 | 09:03 PM
StevensPoint
I greased the **** out of the u-joints and so far so good. I'm going to have to put some more miles on it to know for sure though. I'll report back in a week.
Thanks Guys!
Old Apr 29, 2011 | 09:54 AM
Bkiggins's Avatar
Bkiggins
Thanks Ill pass it on to him.
Old May 9, 2011 | 08:17 AM
StevensPoint
Greasing the u-joints has greatly reduced the problem but I still struggle with the steering once in a while. I plan to grease it again, work it through, and hopefully that will resolve it.
Old May 26, 2011 | 07:43 AM
StevensPoint
I have greased the u-joints twice now and it has almost eliminated the problem. From now on I will grease them every oil change.
Old May 26, 2011 | 08:49 AM
TAT2DUP81's Avatar
TAT2DUP81
Can u post pic of where u greased please?
Old May 26, 2011 | 09:31 AM
bpounds's Avatar
bpounds
I don't want to speak for Steven, but I'm sure it was the zerk on the spider on the front axle U-joints. You can see it on mine in this pic. Not all trucks have them. I think it maybe started in '05, but not positive. Some guys have them but don't know it because you sometimes have to dig around in the gunk to find it.
