My bone stock 2005 Excursion 6.0L throws the SES (Service Engine Soon) light when towing. I can't seem to get these codes from the ScanGauge II. What I am seeing is that there are 2 codes being output, I just cannot seem to read the codes using the ScanGauge II.
Also, when towing, I have been watching the MAP (manifold air pressure). It jumps into high 30s (psia) and then shows a number that is small (say 1.2). What I think is happening is that the display does not show numbers in the 40s.
So, assuming that my MAP is going to say 42 psia, this would make a boost pressure in excess of 27 psig. Is this reasonable? Or, am I getting the SES light because it is considered "overboost"?
The ECT and EOT readings are reasonable, so I don't think there is a problem with oil cooler / EGR coolers. What I suspect is that the turbo VGT is "sticking".
Should I tow with this rig or not? I'm supposed to leave Thursday for a 1500 mile tow through Texas.
You should try to get the codes read. The low number of 1.5 psia is a vacuum at psig, which you should never see in a turbocharged engine. That would make me guess that there is a problem with your MAP sensor and you are getting sensor circuit codes.
I don't know if the check engine light will be set for an overboost, but I do think with the later PCM strategies at least a code will be set. I also don't know what is considered overboost, but I'm pretty sure it's higher than 27 psig.
I have seen my truck overboost before as high as 45 psi and have never recieved a code for it. The only time I have gotten a code for the turbo is a under boost. The normal range for max boost on a stock 6.0 L engine is around 25 psi to 29 psi. My truck at max boost is around 26 to 27 psi.
guys if your reading map and trimg to get what boost readings are your gonna have a hard time.
the calc for it is easy though.
MAP-BARO=MGP (mgp is boost)
I have a boost gauge on mine that comes straight from the intake.
