selling price
its a 2000 F250, extended cab shirt bed, 5.4L, 5 speed, 4x4, manual transfer case, AC, PS, PW, Viper alarm, vent visors, towing mirrors, factory cd player, its got wiring for an amp/sub, bug deflector, 6000k hids, Romick Bull bar, running boards, its got the dana 60 up front, ford 10.5 in rear, runs good, drives good, clutch good. all the following have less than 5k miles on them---285-75-16 cooper discoverer S/T tires, rancho 5000 shocks all the way around, front axle u-joints and front axle seals, new exhaust from y pipe back, new starter, dipstick tube, heater core, both axles flushed, injectors just cleaned(good job at my buddies shop, not just pour in a bottle of cleaner job, toolbox is only couple months old, same with whips. i know im missing some stuff but ill try to add it.
front suspension is TIGHT, needs nothing up there, all ujoints are good in driveline
i was thinkin of starting at $7,000 OBO, and go down to 5500 BOTTOM, i have about $4900 into it
pics
thanks a ton guys, and someday i will get my 7.3
I found that posting advertisement with long list of parts that you changed in last months is NOT making good impression.
If you put $4900 to keep it running, who would like to take it over?
Good luck
I hope you mean $1250 and even that is just crazy!
Speaking of ads. Have you done a comparable search using autotrader.com or other sales websites?
You should be able to pull up a truck similar to yours with the same milage and see what your competition is asking.
You may find that you are willing to settle for way to low...
Good luck
