Transmission doesn't like shifting
Hey guys. Today after leaving the convenience store my transmission started acting funny. It doesn't want to shift out of first gear, I have to get the rpms over 2500 and basically leave it their for a while before it will finally shift. Once out of first it seems like it shifts fine. While in first gear I also notice some noise comming from underneath, almost like a pinging sound. Once out of first it goes away. My Excursion is a 2001 7.3 with 198k miles. 4" exhaust, and Predator Diablo tuner always set to 60hp economy. I reset the pcm back to stock to see if that would make a difference and it did not. I checked the fluid when I got home and it was normal. Please tell me my tranni isnt toast.
Why the output speed sensor? I can't see how that could cause this problem. Why would the sensor only cause a 1-2 shift problem? If it were bad how does it fix itself after the 1-2?
The problem is a failed mechanical diode. That's a type of one way clutch inside the transmission. Unfortunately it means it is rebuild time.
So how many of these ticking time bombs are there out there?
Perry
Perry
Firefighter 1406
10-06-2015 09:09 PM
epos48
06-03-2007 06:55 PM
katoranger
1983 - 2012 Ranger & B-Series
03-08-2001 08:28 AM
