Transmission doesn't like shifting
Old 04-10-2011, 04:51 PM
twisthappyr6's Avatar
twisthappyr6
twisthappyr6 is offline
Hey guys. Today after leaving the convenience store my transmission started acting funny. It doesn't want to shift out of first gear, I have to get the rpms over 2500 and basically leave it their for a while before it will finally shift. Once out of first it seems like it shifts fine. While in first gear I also notice some noise comming from underneath, almost like a pinging sound. Once out of first it goes away. My Excursion is a 2001 7.3 with 198k miles. 4" exhaust, and Predator Diablo tuner always set to 60hp economy. I reset the pcm back to stock to see if that would make a difference and it did not. I checked the fluid when I got home and it was normal. Please tell me my tranni isnt toast.
Old 04-10-2011, 05:13 PM
jh818's Avatar
jh818
jh818 is offline
Might want to check your Output Speed Sensor on the back of the tranny?
Old 04-11-2011, 04:45 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,580 Likes on 1,058 Posts
Why the output speed sensor? I can't see how that could cause this problem. Why would the sensor only cause a 1-2 shift problem? If it were bad how does it fix itself after the 1-2?
The problem is a failed mechanical diode. That's a type of one way clutch inside the transmission. Unfortunately it means it is rebuild time.
Old 04-11-2011, 05:31 AM
Joe28443's Avatar
Joe28443
Joe28443 is offline
Joe28443
I have an 01 myself and I have been waiting to see the same thing. If mine lasts till 198k I will be excited. There are plenty of guys around here that can point you in the right direction for a new one
Old 04-11-2011, 07:25 AM
perryg114's Avatar
perryg114
perryg114 is offline
So how many of these ticking time bombs are there out there?
Perry
Old 04-11-2011, 10:53 AM
jh818's Avatar
jh818
jh818 is offline
Help me understand. If the problem is persistent in shifting in other gears and not just from 1-2, then this sensor could be the culprit? Thanks.
Old 04-11-2011, 11:27 AM
twisthappyr6
Unfortunately I'm thinking you are correct. I found other threads where people were having the exact same issues I'm having and it turned out to be the diode letting go. Apparently this is a common issue with these. I called my local transmission guy and gave him a description of whats going on and he told me the same thing about the diode. Looks like I'm rebuilding.
Old 04-12-2011, 09:12 PM
Mark Kovalsky
All the diesels from the start of 2001 production through March, 2001. I don't know the number that were built.
Old 04-12-2011, 09:37 PM
bradgs's Avatar
bradgs
bradgs is offline
97 F150 same shift problem
I have a 97 F150 5.4L AOD trans with the same 1-2 shift issue. It will shift to second if I let off accelerator a little. Is this also the internal diode or something else.
Old 04-13-2011, 09:12 PM
Mark Kovalsky
No, the F150 didn't have that problem. It's something else.
Old 04-14-2011, 12:36 PM
bradgs's Avatar
bradgs
bradgs is offline
Thanks for the reply Mark, it acts like the throttle pressure rod is too short if it had one. Do you know what replaced that?
Old 04-14-2011, 08:25 PM
Mark Kovalsky
The computer replaced that. You need someone to do a computer/transmission diagnostic.
Old 04-15-2011, 07:43 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Curious what the fluid looks like and smells like?
Old 04-23-2011, 03:39 PM
bradgs's Avatar
bradgs
bradgs is offline
Fluid looks and smells good.
F350fireman
1999 to 2016 Super Duty
02-21-2017 07:40 AM
Redneckfordf2502002
10-10-2015 06:56 AM
Firefighter 1406
10-06-2015 09:09 PM
epos48
06-03-2007 06:55 PM
katoranger
1983 - 2012 Ranger & B-Series
03-08-2001 08:28 AM
Quick Reply: Transmission doesn't like shifting
