thought you had engine problems
Old Apr 22, 2011 | 05:29 AM
  #31
Sullid01's Avatar
Sullid01
It looks like that oil drain pan magnet did a good job of catching the metal bits
Wow, what a mess!
Old Apr 24, 2011 | 11:02 AM
  #32
gearloose1's Avatar
gearloose1
This is for the benefit of Ford Reman / Failure Analysis
Most probable cause of failure is a sleeve for the injectors failed, leading to a trickle coolant leak into a cylinder when the engine was shut down hot.
Other sleeved parts where the sleeve blocks coolant flow should also be investigated.
What then happened when the engine shut down was coolant leaked and filled the cylinder under coolant pressure.
When the engine was restarted, the first stroke expelled much of the coolant into the exhaust manifold, filling several cylinders with coolant at the same time. Then on the next upstroke, the original filled cylinder self destructed.
As the engine continued to rotate, multiple cylinders hydrolocked.
Hence, the destruction occurred at the rods, etc. and there is so little signs of damage elsewhere at the crankshaft, etc.
What this suggest is there is a real quality control issue in the reman process at Ford Reman or whoever the contractor is.
Old Apr 24, 2011 | 11:10 AM
  #33
Zmann's Avatar
Zmann
that didn't happen at start up ,, that happened well above 3k IMHO
Old Apr 24, 2011 | 03:11 PM
  #34
cheezit's Avatar
cheezit
good theory but not at all the case. the one issue with this theory is that would have happened much slower and would not ever kick the keepers out of the valve spriong retainers.
also we know from experance that if we have enugh liquid to hydro a cyclinder it will bend only one rod at start up (think 6.4L and #8 rod)
this was a case of over rev on the engine.
Old Apr 24, 2011 | 05:23 PM
  #35
FishOnOne's Avatar
FishOnOne
That's what I thought happened... Seen a video (won't say where ) with similar results.
68cabby
Missouri Chapter
16
Feb 17, 2013 09:03 AM
chefbill
Jan 16, 2002 08:21 PM
bulabula
Oct 11, 2001 10:24 PM
oz9609
Apr 14, 2001 12:23 AM
AlM
1978 - 1996 Big Bronco
Jan 12, 2001 05:22 AM
