Scanguauge temps
Old Apr 24, 2011 | 05:01 PM
04F-250mark's Avatar
04F-250mark
Scanguauge temps
I was noticing while commuting to Houston that my coolant temp in the morning was 180. Then in the afternoon it will get up to at times 205-210. The question I'm asking what the normal temp should run?
Old Apr 24, 2011 | 05:15 PM
B846B's Avatar
B846B
190-200. There is a recommended readings file in the tech folder.
Old Apr 24, 2011 | 06:12 PM
BLADE35's Avatar
BLADE35
IMO the normal temp should be around 190 unless your working it then it should only go up . 180 seams alittle low. You may want to change your thermistate and see what happens. just my 02
Old Apr 24, 2011 | 06:47 PM
XB70's Avatar
XB70
Not enough information. What the ambient temperature, speed, number of miles from cold start (or is it warm start in the afternoon)? For all we know, you're leaving at 3:00 AM at 45F, driving down hill and coming back at 4:00PM at 80F going up hill.
Whynotgman
1978 - 1996 Big Bronco
Jun 16, 2016 05:04 PM
cory5517
May 25, 2016 10:20 PM
ironbender
6.7L Power Stroke Diesel
May 23, 2016 03:26 AM
Ford are best
May 6, 2013 08:16 AM
bkcowboss
15
Jan 26, 2008 03:00 PM
