Need help w AE!!
Old Apr 17, 2011 | 09:12 PM
woodnthings's Avatar
woodnthings
More than likely it was not the IPR. With you jumping the truck, you provided more cranking amps. That may indicate weak batteries or could even be a bad starter.
Here is an article on the IPR Rebuild
IPR Rebuild
Old Apr 17, 2011 | 09:25 PM
JT250's Avatar
JT250
Hey thanks a bunch for your help. I know my buddy appreciates it too. I am going to put new batteries on it tomorrow, then we will go from there.
Old Apr 18, 2011 | 07:50 PM
F350-6's Avatar
F350-6
If you refilled the HPOP reservoir and still got 0 psi and 64% duty cycle while cranking, I wouldn't just write it off to batteries. Something to keep an eye on. If you decide to pull the IPR, make sure you've got some new o-rings to use when you stick it back in.
Old Apr 18, 2011 | 08:10 PM
JT250's Avatar
JT250
He also has the gray CPA in the truck. I ordered one from clay to replace it. I can't remember.....do u do anything to the IPR when you rebuild the hpop res. Did mine last year but I can't remember. It takes 3-5 seconds to start then runs a little rough. I will stick the cps in and see if anything changes. He needed it and for now it will start.
Pikachu
36
Mar 29, 2019 02:44 PM
Rollingscrapmetal
Oct 3, 2016 03:05 PM
JohnDeereFarmerUSMC
Jul 14, 2015 10:08 PM
snakedoc
13
Jan 17, 2014 08:16 PM
FordmanShane
Aug 21, 2012 07:17 PM
