GPR LED
Old Apr 16, 2011 | 10:02 AM
new2diesel's Avatar
new2diesel
GPR LED
Ok, I'll try this a 2nd time. 1st post didn't show up. Last weekend I did my spring under hood cleaning with simplegreen. After I decided to install the
GPR LED that I had. I did the install and tried it but it didn't work. Checked all
my wiring and tried a couple more times then it started working, I assumed it
was because it was so warm out that the computer wasn't calling for the relay
(which was replaced about a month earlier). I monitored it all week and figured it was the "new" relay. So this morning when I installed my new ICP and HPx
(thanks Clay), I decided to install an "old" relay that I had in my toolbox.
Turns out the LED is working fine, and my brand new relay is crap.
So the purpose of this post is to inform that not all new parts are perfect.
I hope this may help someone!
Jeff
Old Apr 16, 2011 | 10:24 AM
woodnthings's Avatar
woodnthings
It did post.
https://www.ford-trucks.com/forums/1059281-gpr-led.html
Old Apr 16, 2011 | 11:18 AM
clintbonnie's Avatar
clintbonnie
Just check the large lug on the drivers side of the GPR for voltage, should be around 11v..when cold..if you have voltage here, your LED wiring, etc is at fault..
Old Apr 16, 2011 | 01:40 PM
new2diesel's Avatar
new2diesel
I did check all the wiring, thats why I decided to try my old gpr, and that confirmed
timmyboy76
Mar 24, 2014 08:00 AM
bakerbuilttracks
19
Dec 2, 2013 10:08 PM
Backdraft-14
Mar 17, 2012 05:16 PM
new2diesel
Apr 16, 2011 01:38 PM
derekmj64
18
Mar 11, 2008 10:03 AM
